Should I feel nitrogen gas in my tires because I heard nitrogen saves the tire even more than normal air. Is this true that normal air can cause tire blow out because its hotter than nitrogen gas.
prodigy said:Nitrogen's only advantage over air is that it doesn't expand under hot conditions therefore maintaining tire pressure. Maybe if you're into real high performance tuning, filing your tires with nitrogen will ensure your car will run in optimum wheel settings all the time.
However, it doesn't mean by filling nitrogen, you pressure won't escape. A nicely fitted tire will not lose is pressure easily where else if your foreman has been doing a crappy job, even you fill with air or nitrogen, it will also escape.
haha... u tried ar??eterna22 said:a little off topic....try inhale nitrogen .... similar with cocain la ... dem highh
AccordRacing said:i dont agree about that,now its say filling nitrogen,sure we have to idealism little bit tat the work is done perfect,if u say crappy work..then wat good stuff u install also got defect just becoz ur foreman crappy skill,the advantage of using nitrogen to fill in tyre oledi proven..just c u believe it or not
