Aeromotive A1000-6 fuel regulator kit
dre42
7,000 RPM
http://img806.imageshack.us/img806/7888/drego.jpg
Uploaded with ImageShack.us
For high-horsepower EFI applications where -6 AN lines are used.
These Aeromotive A1000-6 injected bypass regulators were developed for high-horsepower EFI applications where -6 AN fuel lines are used for supply and return. These regulators are alcohol compatible and feature two -6 AN inlet ports and one -6 AN return port. They're beautifully finished with Type II bright red and clear anodized coatings and deliver long life, performance, and reliable operation.
-fully adjustable for your ideal base pressure. Fuel pressure rises on a 1:1 ratio when referencing boost.
-stainless steel hardware, including custom designed spring and mounting bracket.
-bodies and caps CNC-machined from 6061-T651 billet aluminum alloy.
-type II bright dip anodized finishes (except as noted) provide good-looking corrosion protection.
-all vacuum/boost fittings are CNC-machined from stainless steel.
-base pressure regulator is adjustable from 30 to 70 PSI.
-alcohol compatible.
-provides two inlet ports and one return port.
-fuel pressure will rise on a 1:1 ratio when referencing boost.
-1/8” NPT gauge port.
-the clear anodized finish on the body completes a truly elegant design.
RM380
DREGO IMPORTS
(001990983-A)
NO.6-M JALAN PJS 7/20B ,BANDAR SUNWAY
bring up post ..cheers
Drego imports (001990983-a)
49d jalan pjs 1/48 petaling utama 7
off old klang road, 46150 petaling jaya,selangor
malaysia
office : +60377811481
mob : +60123505832
malaysia
mob : +60123505832
malaysia
mob : +60123505832
malaysia
mob : +60123505832
DREGO IMPORTS (001990983-A)
GPS: 3.073991,101.61681
DREGO IMPORTS
No.6-M, Jalan PJS 7/20B,
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
[email protected]
MOB : +60123505832
OFFICE :0356361481
DREGO IMPORTS
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
[email protected]
MOB : +60123505832
OFFICE :0356361481
DREGO IMPORTS
Bandar Sunway,
46150 Petaling Jaya
Selangor, Malaysia
[email protected]
MOB : +60123505832
OFFICE :0356361481
