ae 92 tip top
ae 92 tip top
rayracing79
se limited untul di jual,body 1600cc,tahun di buat 1992 last model,
body tip top no accident (i cerewet cari keta dekat 4 bulan)
engine spec
ae92 super charger
large pully(175mm)
front mount intercooler(itc baru cap ayam apex)
rca
tein adjusterbel
momo deep dish 60mm ori, boost kit panjang(ambik balik)
sound system,
petang baru tukar cermin cromax
D&D radiator aluminium,(burble tank
sard ori radiator cap
blitz limited open port dengan air ram honda sawah
tom new action rim 15 inch,7jj offset 35
tire achelies 123 semi slick baru 2 minggu
room bar
TRD anti roll bar
body part levin
philips hi low beam,beli 2 k plus(6bulan)
meter panjang,
gear box semi lsd(lucas lsd oil)
dalaman semua tip top banding dgn ae92 yang pernah aku tengok
pull star plug (rm 350)baru 3 minggu
Tnabe limit ax 4-2-1
piping 2,3
mid box 2,3 ori hks
muffler hks super dragger 2,3
bushing semua pu(3 bulan)
steering rack baru(2 minggu)
lower arm ball join semua baru(1 bulan)
brake servo double layer,
battery yokohama baru 3 bulan
alternator baru
valve seal baru
power steering pump refurbish
tie rod end baru
fuel pump baru
belting semua baru.
cermin depan belakang bukak keluar gam balik
pintu sound proof
OIL CATCH TANK,
HEAD ADA DAH PORT SEKALI VALVE,TAPI BAYAR DUIT UPAH PASANG, TAPI HEAD KENA SWAP BALIK,NAK BALIK MODAL PORTING HEAD JE 600
CAM ADA TODA EXT 272,HKS FUEL 264, TAK PASANG LAGI OPTIANAAL 1600 JALAN
POWER STEERING OIL COOLER CANADA BARU OPTION 800
VALVE DAH BUAT CONTOH BAWAH OPTION 300
nanti ingat i tulis lagi, malas nak check resit
DYNO ON WHEEL HP 137,TOQ 18
semua ada resit.. rm 17000 nego , serious buyer only
