ada problem la kawan
qmb_rocket
seven sky
:smile: allo bro..... some question loh?........i used EG 1.5 sohc vtec auto but now the engine have knocking sound especially after start the engine, petrol comsumption high somehow like driving lori....rpm so heavy & engine too berat.... check light blinking no 19.....and also some knocking sound at the left rear when brake or press pedal.....
It is because of timing or anything else.... where to make tuning?
to Fairuz don't forget to call me regarding HCOC and to Ray69 lu call me lah kalu ada any stuff to let go (putra amcorp)......
honda yg hensem... :dancing2: :rock:
u really got problem la bro...
and soon u'll have a problem with Tom heheheh...this is an english medium website la bro hehehe...
It seems from the limited info u gave, the problem is more than just timing and re-tuning. I'd seriously recommend u to check all the internals...
it looks like parts failing to me more than tuning
come to avantgarde lah bro, i ask the shop charge u cheaper, let the mech see what they can do for u, not happy can choose not to do
i recommend u bring ur car go see doctor soon to prevent further problems arrising ler
firstly, sorry tom...hehehehe... and thanks to everybody...errr..one more thing where the place to tuning... :albertein
Dude, almost all good mechs can tune any car. The only difference is they way they do it. Some use laptops, some use combination of PC power and 'ol skool tuning...while others just know the "put-the-metal-pipe-and-listen" technique...and with different technique comes the difference in $$ heheh...
But as we said earlier, your problem extends beyond the tuning category. Relax, we've all (or at least me) have been through your episode before..
some even using a long screw driver to listen .. hahahahaha
are yu sure its knocking kaa ..?? .. hows the sound like .. knocking or ticking ..
bro,when u said ur petrol consumption is high, how high is actually? any data?
for the check light, i seriously recommend you to visit your favourite mechanic, otherwise other worse thing will happen.
like crower said, most of the mechanic can check for you, best thing is to take one day leave and go to several shops, and make your wise judgement from there.
cheers!
Just to share my experience, i was in that situation past 2 years..same problem with you and the best way to solve it is get new engine or do transplant to B16A..
- error code 19 -
Automatic transmission lock up control solenoid valve - defective circuit or unplugged ..
hehehe...usually syiokGILER would be THE person to consult on blinking checklights and suspensions....heheheheh...........
Maybe this is his apprentice.....
is there someone else using the same nick kaa ..???
crower
yu can get error codes easily from the net laa .
udengfahlawi said:
cekau = syiokgiler?...
I know that these codes are available from the net...but only syiokGILER memorises them by heart hahahahahhaha.........
crower
you must be different person then...the syiokgiler we know also use nick cekau, but in different forum laa....sorry for the confusion....
Write your reply...
