ABS problem after changing brake pads
I have changed my stock pads to Endless 300deg C VN9500 for some time and never had any problems with any noise. The endless pad were design to be used with standard cars for normal driving.
Better check if the Sumitomo pads are suitable or maybe there are other problems with your braking system that just coincidently appear after you have changed your pads.
I never had this problem before i change the pads, only after that.. sigh.. the problem is with the ABS.. and the sound will only be there when the car is nearly stop.. if i drive in normal speed or high speed, the sound wont be there even tho i brake it hardly..
In that case..better go have it check before something else happens...no point just worrying about it.
