A32 Drive Shaft Problem~
JasonKam
Tmn Kinrara S'2
hi all sifu and pro,i just purchase A32 3month ago...everything is just fine due to the ex-owner is careful driver...after 1 month,i changed to 18" rim using 225/50 series tyres with 1 set of adjustable suspension to dropped it until zero finger gap (tyres tuck in fender),my drive shaft got knock-ing sound...
i already changed another set drive shaft but after 2week,the sound come back again....
did i need to changed another set drive shaft again?
or adjust my suspension back to normal height?
pls help me~
when u say knocking sound .. does it only happen when u go over bumps or uneven road? if yes, then up your ride height. just a word of advise, be prepare to change wheel bearings also if u lower it too much & running on 18". i just changed my 2nd set of wheel bearings (front & back) totalling to rm1020. symptoms of a "kong" wheel bearing is, its is damn noisy & annoying when u drive as if u r in a airplane!
hah? where u changed bearing,so expensive....lucky my wheel bearing still in good condition....
already changed to another set drive shaft,just adjust my ride height,hope it will be ok later~ now rolling on 1 1/2 finger gap on front and 2 1/2 finger gap on rear~
Lowering ride height = driveshaft problem for most A32. Don't believe check it out with cefiro specialist.
Just wonder whether cause by too much offset.
But this offset was reasonable.
I even use +35.
So previous change driveshaft was Re-condition or Chop Shop one ?
Wonder how much is the cost you change.
Which brand of Adjustable Absorber you use ?
Again how much for that ??
I also think to change it but not for lower just for better handling !!
haiz~if can`t lowered more then can`t play vip style already~
Aiyah, just slam it down during vip photo shoot and make it normal ride height for normal daily driving just like some of the senior bros:biggrin: here.
cannot upgrade to citroen like hydrolic suspensions? so u can adjust it high when banjir, and adjust it low to show off... :)
I even use +35.
driveshaft from chop shop~(driveshaft/RM190+labour/RM30)
D2 Hi/Low adjustable "New" (RM2k+) without installation~
good handling at cornering and highway use~
for better handling,it`s depend on your rim size(wide),tyre size & type,wat type of suspension u use.....(^_
it`s all about the setting of your car~
