93t and 93p air flow sensor different?
beeboy
hi does replacing the 93t air senor increase HP on my gti with bolt on ems bolt on turbo?
Hi, replacing the air flow sensor on your 4G93P to the 93T IMHO does not increase HP. It will however make your car run smoother.
4G93P = 499
4G93T = 449
The NA air flow is not meant for turbo aplications, however it'll still work but you'll notice that your AF will fluctuate more during cruising and on-boost whereas with the turbo AF sensor AF will remain quite constant... I've changed mine before and can say that its a good mod.
Let me know if you're lookig for one... I have one to let go and its still running in my car now :P
4G93P = 499
4G93T = 449
if not mistaken.....if you check on 1.8 Wira year 96 & 97, they are using 449 AFS too......you cant really diff. from outlook but if you check in detail inside the lubang there will be diff. :D
