acura said:asking about stock 180sx .... does it have like a blow of valve Originally or what?
i was planning to get a BOV.. but i dunno if i should.. cos the fuel consumption is already quite high.. if i added that.. would it make it worst? and what brand should i take ? any suggestions?
MizuChi said:The SR20DET has the stock BOV fitted right next to the intercooler inside the left inner fender. If you plan to fit on an aftermarket BOV, you're better off getting one that you fit on the topside of the engine, instead of a secluded place like the inner fender. If you plan to do that, you'll need to take off the stock BOV and cork the holes up.
AFAIK BOVs has no effect on fuel efficiency, but it will have an effect on engine response. I found that no BOV seems to have the best response. There is almost no lag, since the pressurized air is kept pressurized inside the piping. The only downside to this is that if you plan to raise the boost on stock S13/S14 turbines, no BOV may ruin your turbines faster, since the pressurized air will make its way back into the turbines during gear change. You'll get to hear a cool sound though.
acura said:where is da list??
1 ) acura ( 200sx)
2 ) 7urn57yl3 (S13 Silvia)
3) eci™ ( 180sx )
4)CHIN (SIL80SX)
5) URAS - (onevia)
6) rps13_R (180SX)
7) JUN [180SX]
8) Deep$hi+$ (S15)
9)alfeoturbo(S15)
10)akimoto (180sx)
11)dorifto_demon (180sx)
12)lionelk (180sx)
13) kennji (S15)
14) Brian (240sx)
15) Chai (180sx)
16) temujin (180sx)
17) Fly240sx (240sx)
Deep$hi+$ said:Ok here how things work..
First, you have to take a photo of your cracked windscreen.Make sure the photo that you take really show clear where's the crack . Then, you got to pay first and have someone to install for you. Once everything done, you need to get the original invoice/receipt from the guys/supplier and submit to the insurance company to be claim. After about 3 to 6 month , you will get your submission receipt/invoice amount back in a cheque form. And sll the steps above you have to do it yourself. (DIY)
Honestly, I am still unsure how much a S15 windscreen cost. Usually, this things need to be import from Japan. I am still planning to increase the insured sum to Rm 7000/pcs. Afterall, the premium is not that high. Any1 know the actual cost of windscreen can share info a bit Thanks
