price $65 000 usd
engine V12
valvetrain DOHC 4 Valves / Cyl
displacement 5167 cc / 315.3 cu in
bore 85.5 mm / 3.37 in
stroke 75 mm / 2.95 in
compression 9.5:1
power 335.6 kw / 450.0 bhp @ 6800 rpm
hp per litre 87.09 bhp per litre
bhp/weight
torque 500.3 nm / 369.0 ft lbs @ 4500 rpm
drive wheels Front Engine / 4WD
body / frame Aluminium & PFibreglass Panels
front brakes Vented Discs
front wheels F 43.2 x 27.9 cm / 17.0 x 11.0 in
rear wheels R 43.2 x 27.9 cm / 17.0 x 11.0 in
front tire size 325/65VR-17
rear tire size 325/65VR-17
steering Recirculating Ball w/Power Assist
weight 2700 kg / 5952 lbs
wheelbase 3000 mm / 118.1 in
front track 1615 mm / 63.6 in
rear track 1615 mm / 63.6 in
length 4900 mm / 192.9 in
width 2000 mm / 78.7 in
height 1850 mm / 72.8 in
transmission 5-Speed Manual
gear ratios 2.99:1, 1.90:1, 1.33:1, 1.00:1, 0.89:1
final drive 4.125:1
top speed 210 kph / 130.5 mph
0 - 60 mph 7.7 seconds
engine V12
compression 9.5:1
bhp/weight
final drive 4.125:1
