Dear toyota brothers and sisters, i'm driving AE110, 5AFE engine. JDM model. recently, there is this irritating sound. from the engine bay, which increases with speed. it is a continuous ticking/clicking sound from the engine area,confirm not from underneath dashboard. it only increases with speed. NOT RPM.tested!. tests: Jack up car. start car on neutral mode. ram RPM, no sound heard. Engage to D mode. sound increases with speed. With tires spinning, switch to neutral mode,sound still audible. stop engine. turn tires using hand. sound audible. checks: a throughout check by dismantling the drive shaft, left and right hand, change shaft boot,re greased. replaced gear box oil seal but to no avail. dismantle RPM cable .sound audible, removed rpm helical gear from Gearbox. upon inspection, gears all perfect. i've refered to several mechanic but still fail to locate the sound. some suggested gearbox overhaul :( could that be the source of sound. one more thing recently found out, when cornering to the left, sound is loudest. straight road, sound is audible. cornering right, sound is much softer. HELP :(
:wavey:
