Need Advice - 20VBT coughing carbon deposits
gilbert
To all toyota bro's, i notice my ride was coughing out carbon deposits through the exhaust early in the morning when i start it. Secondly, symptoms of engine oil decreasing was a also observed and i need to top it up like once a week. Just recently transplanted about two months back with e-manage. This issue has been bugging me for the past few weeks. Is this normal?
Looks like you need to overhaul already... must be revving the heck out of it yah? Hehe...
Well, suspect piston ring and valve seals worn out.
At the mean time, have you checked the spark plugs?
"coughing out carbon deposits" ...heee mine too...it's mainly because of old piping n muffler system...carbon filled up already, chocking the fiber inside it, perhaps...my engine on very healthy condition, newly rebuild 15k km olready... :D
Oil decreasing ? any white smoke during idling or high rev ? any oil leakage ? any engine overheat ?
Okay, that seems to be a major issue. Din rev much though. Just sent for dyno 3 times and the result was this. Will try checking the spark plugs first as mentioned if nothing wrong means could be the valve seals and piston ring then. Dang, i hardly whack it that hard. Just occasional abuse i guess. By the way, there's white smoke coming out during cold start but after that it becomes normal.
---------- Post added at 04:58 PM ---------- 6 hour anti-bump limit - Previous post was at 04:55 PM ----------
On thing i forgot to mention, the piping was new so i guess that wouldn't be the culprit. No oil leakage and overheat. My biggest suspicion would be the valve seals and piston ring too. But hopefully that isn't true.
Nah, it sounded normal though. How come yours sounded like diesel. Mind to elaborate what causing it ?
20v = diesel engine ma...wakakaka...my bro-in-law asked me b4 is my corolla diesel?? hehehe..
Yup.. sounds like diesel..but dont worry.. we already discuss this topic about a few weeks ago.. some sifu says this is normal for 20V engine.. they said maybe my VVT need to service... You can only hear the sound during engine idling..but after the padal is pumped..you know what i mean.. 20V screaming..!!you can search for my thread to read more.. just FYI..
oil topup once a week is consider quite serious. actually base on the symptom above, what you dont wish to happen is actually happened. bring it to mechanic is the best rather than guessing and make ur day down.
faced this prob when i was using BT20V last time. No oil leaks at all. happens maybe due to piston ring or valve seal. will come worst if high rev. black smoke, comfirm. in high rev some more. some time fire cominf out from the exhaust. it's fun.... vtec prrrannngggggg bt pringgggg
