Problem with exhaust manifold
kk13
Hi guys,
Around September last year there was this ticking sound coming from the back of the engine bay. I took it to my mechanic and he said that my exhaust manifold was leaking. He told me that he would have to remove the turbo and re weld the exhaust manifold. He did so and after the sound was gone and the pick up improved a lot as well.
Towards the end of last year the ticking sound started to come back, first it wasn't that loud, but now it has become louder. I'm guessing its the exhaust manifold again. My question is..
Is there any permanent fix to this problem?
If I have a custom one made or got an aftermarket one would it help?
Or is there a better way to weld it?
Also, do you guys know anyone who would be good at fixing this sort of problem?
Thanks guys... :banghead::banghead::banghead:
WIth the single setup you've got i reckon you should get another manifold made. Jaffa or Ah Heng opposite ah choy can get it done properly. Its going to be a whole day affair though. Good luck.
Thanks phat7,
how much do u think it would cost?
Safely about 1k to 1.5k for good job. They must also take into consideration the "allowable free play when the engine moves. Check your engine mounts as well to make sure there is no excessive play which moves the manifold and causes cracks.
usually I take it to ah heng opposite ah choy's place whn i comes to the exhaust...he should know what to do and take into consideration all tat you mentioned above right...
