Install trumpet inside plenum. Any difference???
actually is not recomended to use high cam, now a lot modification is not using high cam la, bcs the timing will not stable also, but if got ppl use it then timing still stable pls let me know. and then better to keep the vvt......actually if u need performance a lot thing u can do....
u can't play with vtecs without high cams. fyi, 272 cams still give stable idling. u won't go FAR without cams. that's the most obvious HP gains compared to other mods (except BOT). u need another piggyback or standalone to further fine tune ur cams settings. just my 2 cents:smokin:
hmm..but,how we know that the trumpet height coz normally seller didnt give the details on the dimension?if we buy then it wont fit, then it a waste&need to send to the machine shop..IMEC trumpet that I've saw, normally the pricetag is bout 400++ wor,lot xpensive than the aluminium or alloy trumpet:hmmmm2:
It will not fit if the tapak is different. BT trumpet cannot fit SVT tb and vice-versa. That's the only issue of 'cannot fit' that i can think of.
regarding the length, u can ask the seller to measure for u. shouldn't be a hassle if the seller wanna do business.
pcmoddingmy: interesting with your DIY. can u show us the step?
Basically u just need 4 pieces of stainless steel cups, can get them from any indian shops near masjid jamek or brickfields or any other shops selling indian cookware n stuff like that. Various sizes available from 2" all the way to 4". Then for the flange, u can try to source them from exhaust pipe shops or CNC them if you have a fren working with CNC machine. To get the flange dimension, you can either go to chopshops/workshops to measure it (look for BT ITB) but note that BT and SVT ITB has different sizes. Don't use the rubber trumpet that comes stock with the ITB because the diameter is smaller than the actual ITB's mouth.
Then once you have the SS cups and flange, just need to weld them together and cut the bottom part of the cup. You can also use super strong glue (JB weld) to glue the cups to the flange but the result might not be nice for your eyes, unless you don't plan to showoff ur trumpet to your buddies I guess it doesn't matter how it looks if its inside the plenum...as long it does its job right.
Happy DIYing!
Thanks a lot! will do it tomorrow...
the flange will make it at friend shop..
firstly the sound from the 'open' trumpets is 'sweet'.
its function is to improve the 'flow' characteristics into the engine.
The actual gain is marginal except @ wide open throttle-without air filter restriction.
If installed inside plenum should use shorter trumpets lest the clearance from plenum body actually restricts air flow.As pcmoddingmy indicated you got to match diameter of trumpet to ITB.
It does not affect FC-usually its driver 'foot happy' becoz of the sound..hehe
Coupled with high compression pistons and high cams is when it actually gives a significant advantage.
That's why I'm so eager to install the trumpet coz wanna feel myself how 'sssswwwwweeeettttt' the sound is....later,might be poisoned by sifu2 to be one who had a 'heavy-footed disease'...hehehe....but,I've read from the previous thread that open trumpet is not advisable coz the dust and harsh particles could enter into the engine same goes to the owner who use a subaru-like bonnet cos when in a rainy day, water could enter the engine via the trumpet.....hmmm,need to think very very wisely when imaging all these thing could happen:hmmmm:...sory aaa if I'm so talkative
Regarding the sound... i didn't feel much difference if installed inside the plenum, but the type of intake air filter used also plays an important role. If using HKS mushroom filter, I think the ITB roar will be louder. I myself using Apexi dual funnel, sound wise not much difference after swapping out the rubber OEM trumpet to SS trumpet. However, remove the plenum and you will be an immediate crowd pleaser. ;)
Trumpets aka velocity stacks doesn't necessarily increase HP, its more of a responsive improvement thingy. Just to note...
well, open trumpet is nice but it'll 'choke' a bit when your rpm is around 3-4k range. but after that... ;)
don't floor the throttle when u are around 2-3k rpm. slowly press down the throttle. when it passes 3.5k-4k rpm then only u floor it. u'll be amazed. :D
Its not so much the trumpets but your cam and AFR.In stock mode the BT VVT kicks in @ 4400rpm but with the 272 cams the intake opens about 20deg earlier so you got to retune and that should take care of it.
Regarding the AFR,how to adjust it?coz my car seems to hav a misfiring sound and quite frequent there's a 'fuel-cut' feeling eventhough I'm not pressing till the redline....does it bcoz of the AFR or something else...my car really need to meet the 'specialist doctor' bout its illness
this is actually symptom of O2 sensor getting faulty...:banghead:
owh really?! hmmm, i was a bit suspicious when i did that O2 sensor test. multimeter works fine (moved up when i press throttle and down when i released throttle) except when i maintain the rpm @ 2500, the meter will be idle in the middle. It didn't move more than 8 times in 10 secs. actually... it doesn't move at all... LOL :banghead:
now the hard part, where to get a new/working used sensor? :confused:
yup, quite pricey...
do inform if you manage to secure the item with a good price...
coz many from Club4AGE changed to Bosch LS05... however i've been quoted at RM469 by the Bosch dealer...:banghead:
related to trumpet... just to share not promoting...
http://drift.com.my/forum/viewtopic.php?t=37188
good bell-mouth shape...:biggrin:
Just called up an authorised Bosch distributor in Butterworth. I asked him what's the model and he said it's for universal use. he didn't give me the model number :banghead:. He said any car can use. the kit comes with application chart and wiring diagram. He said as long as u hook it up correctly the 4 wires, then it should be working. No return after buying cos i said i'm a car owner (customer), not from any spare part shops.
the price he quoted me for a brand new one is RM350.
anyone interested?
anyone interested?
remember if using Bosch LS05 (yes it's universal)... you need to put a new 'bung' to your extractor... coz this is not like ori Toyota O2 where there's a flange instead...:banghead:
good luck...
is the 'bung' same as the one they used to cucuk in the wideband sensor during tuning?
