hi...
i'm a new member to this forum here...
found out those member over here really looks funs with those topic...
and i'm also a 4G92P owner...
hehe~
hello everyone. another wira 4g92p reporting in. im newbie in here
this is my modification
- auto to 1.6 manual gear box from satria
- 4g93t intake manifold
- evo 3 tb without tps
- ngk platinum plugs
- huriccane plug 10.5mm cable
- works fuel regulator
- putra exhaust wit 2" piping
- hot bits 4-2-1 header
- k&n drop in filter
- alloy crank pulley
- lighter & balanced flywheel
i saw the previous post that the rev limit can go up to 7500rpm. can the fuel pump supply enough fuel after 6800rpm cause the original rev limit is 6800rpm. is there any other cheap modification that can be done to this engine??? like swap the parts to mitsubishi parts
thanks....
huhuhuhu sorry guys because i'm using short form...masyukk..what gb is that???your car running 4wd???
i not really know the gb is came from wut model...because it's a 2nd hand car...and i buy it just like that...er..no..i understand that shortform...but unsure about that gb model came from evo or gsr or mirage?then only u can decide to change same gb or find other models of gb....
and really your car endorsed with that 4wd..if yes i wanna see it....because it was rare occasion 4wd can be approved....![]()
