15 inci enkei j speed 2pieces type pcd100
kanglee
15" enkei j speed 2pieces type, rim spec offset 32,6.5j,pcd 100, selling prices rm1650 pls call 012-3769412.
Sorry to highjack the thread with a question but,
I'd like to know what the PCD, J and offset refers to...
As per my knowledge, for tyres, if it's 205/55/15, it means 205 = width, 55 = tyre height from the rim and 15 = rim size....
so please, explain to me what PCD, J and offset refers to where rims are concerned.
Thanks
Thanks
Offset
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
http://www.discounttiredirect.com/images/wheel.offset.gif
more positive offset = rim (plus tire) terkeluar sket
more negative offset = rim (plus tire) masuk sket ke dlm
hope this helps
wow this rim good for kelisa with wheel arch
