Anyone transplant 3SGE dual VVTI into SEG AE101 body?
Sil80-13
Hi guys,
Just wondering anyone transplant 3SGE dual VVTI engine into local SEG AE101 body? If yes, please put some input...
All engine mounting & gearbox mounting need to modify? And is the mountings can be modded nicely?
If this transplant is possible, then I think this is better than futher upgrade the 20V engines. More HP & no need to spend more...:biggrin:
Hi guys,
Aiya... you baru tau ar? Sudah lambat lo... Wahahaha...
BT where got so powerful le? You spend so much, only get little in return... What for? Sorry for BT fan, I not hamtam BT but I only said BT can't go beyond than 1.6 category and only perform good in category 1.6 only.
Anyway, the all engine mounting and gearbox mount is need to mod... No mod no fit...
How is maintenance for the 3SGE engine? Spare parts availability? Tuneability? newbie here..sorry for the questions :)
Some part can share with Camry le... Toyota build tough, so don't worry about it...
call power speed kajang 0192174320......they did before............last time back in 2003/04 many seg AE101 use either 3sge or 3sgte.......nowadays hard to see them...... 3S vvti not much stuff to play coz a bit advanced....no more using plug cable....running on plug coil....but i do found exhaust extractor for it last time n it is cheap.....timing belt n etc is the same as other 3Sge n can get locally....
i ask power speed recently about charges coz 1 guy also thinking of transplant into his seg
labour RM2000
parts e,g driveshaft, radiator n etc RM1K+
so roughly cost for everything including halfcut around RM8K........almost same price as fitting bt 6sp
yeah.. tat fei lo nga got well experience on this kind of conversion ... hahah
but how about JPJ endorsement procedure? any problem on cc upgrade? let say from 1.6 or 1.3 or 1.5cc body ( mine ori is 1,5cc )
1587 CC + 25% LAW = 1983.5cc.. not enuf ler?
runner can settle this ?
hahhahaha...
"pandai nyer"
thanks for the lesson from Jika Pay Jalan,or else I dont't know how to get the figures or calculation.
back to the topic,i was interested on this conversion before but according to sifus here,the handling will be pretty much affected after this conversion,hence another concern other than power & brake is the suspension setting.never had a chance to ride on a 3S powered SEG tho...
anyway,since many taikor here recommended few experienced mechs in such conversion,u may go & survey then share with us here :top:
Frankly, I never seen it been done before. But i've seen a couple of 3SGE Beams single VVTI (redtop) transplanted into AE101 chassis. However, I believe almost every engine mount had to be modified and the weight balance will be disturbed.
Converting 3SGE Beams Dual VVTI (from Alteza) is rather difficult because its designed for FR platform. So you need to work on the engine mounts, water lines and matching the right gearbox is going to be an issue as well.
If you want sheer power, I would suggest to go with 3SGTE instead. 3SGTE parts are much cheaper and HP gain is phenomenal as compared to NA. Besides sourcing 3SGE Beams parts is quite hard as rarely you can see performance parts for 3SGE Beams DVVIT or VVTI engine.
Also, I think JPJ approval might not be possible if done legally as for 1.6 chassis to 2.0 is over the allowed limit. Even if u get it done by "jalan", you car will still be compounded during JPJ roadblock. IMO, AE101 1.6 chassis max allowed within legal limits should be 1.8... which reminds me of the awesome power of LIFT with the 2ZZGE! Maybe u can consider plonking in a 2ZZGE all aluminium motor and feel the power of LIFT beyond 6000rpm till redline.
Yes... the 3SGTE are the most economic way to get HP...
2ZZGE i also not so recommend, because the halfcut abit pricy le... another is damn hard to find it too...
Anyway... 1.6 to 2.0 in Toyota and Honda will get approve without feeding too... My friend all use AE92 1.6 and put in the 3SGTE le... no problem found le... My friend ask the Puspakom, they said only proton car was not allowed... But Toyota and Honda may increase up to 30%
hehe...too late lar now... im using 3sgte in my seg registered in 2004 so far so good..
Handling...Toyota seg body was tight enough to handle 2.0cc syarat nya ada adjustable depan belakang...also u need SAFC 2 to reduce fuel cosumptions....
engines Spareparts mostly same as camry n Corona...
"i ask power speed recently about charges coz 1 guy also thinking of transplant into his seg"
Aiyoo, thanks for tom's for not direct putting my name in there...
I have been researching for so long now what halfcut to put in my car to replace my trusty 4A-(FE, auto summore hehehe..).
Adjustable ada dah, brake depan pun pakai ST205 dah...
I know 3SGE/GTE transplant is doable. About same money as 6 speed BT transplant.
I have actually bought a 3S Power Enterprise timing belt from a forummer here just to convince myself that one day I must commit to do this transplant!!
But only the money, or lack of money is stopping me... susu dan pampers lebih penting :biggrin:
Anyway my 4AFE auto is strong enough to propel the car fast downhill Karak. Kalah ngan Evo je:rofl:
since you mentioned 4AFE...
there's one of my colleague...still using it still going strong...
then Tom's said to him...when do you want to transplant the engine ? then that fella said...
"until this engine (4afe) broke down..."
hahahahaha...is it possible the 4afe to break down ? hhahahaah...it's one hell super strong durable engine...where can broke down... :D
Why not possible le? Just put the sand and campur with the Cylinder oil lo... Then you will know the result... Wahahahaha...
Or else, go to remove all water and cylinder oil, then run the engine kaw kaw... Wahahaha...:rofl::rofl::rofl:
hahaha... 6 pot front and 4 pot rear lor.... Sure safety...:P
yeahhh..look at big brake at front & rear not mean car will stop immediately...imagine 180Km speed, izzit your car will stop 5 meter from your breaking point? :driver:
so sayang my 4AFE, can go 180km/h(turun bukit only lah). 400 000km already...
But begin to eat oil already. When white & blake & blue smoke come out, then will convert. 7afe maybe??:biggrin:
From 180km/h to full stop, wow.... 40meter plus can ah?? With full slick boleh kot....
Mat..that timing belt sell to me lahh....
