No boost on evo3
guest
Kota Kinabalu
im using evo3 engine and after a while "tarik"(got boost 0.6bar)....suddenly i saw there is no boost increase as the needle jjust stayed 0 at my boost meter...i step hard the padel and the is no boost on all the gears....what happend?turbo kong?help help
check if any vacuum hose got disconnect, normally at your actuator....
nothing to do with turbo kong or bov kong?haiya takut2....y ahh/.///:banghead: cos the car also running like NA...no G force already....just now tarik2 got G force...now no boost n no G force....uwaaaaaaaaa
-crack manifold/banana (bocor)
-turbo kong/jam (shaft,fins problem)
uwa..these 2 things ahh...aiya.....how to know ahh manifold crack?actuator also kong?but as far i can c now...there is no smoke coming out from my exaust....
---------- Post added at 08:00 PM ---------- Previous post was at 07:43 PM ----------
Help...help...
if turbo not leaking means either actuator kacau or intercooler piping leak or both
or your boost meter vacuum hose cabut
Hi bro,tis is ur bov problem n if u notice ur blow off doesn't make sound like usual n wat u hear is the sound from ur air filter when u go on high rev.Cheers
using actuator or external wesgate.. if actuator suspected ur flapper or turbine housing crack..
thanks guys....no sound from bov as no boost only 0.....vacum got lah...em...im using actuator...
check if got shaft play, check if the shaft is jam or anything, check ur intercooler piping, do a boost leak test, check ur actuator koyak already or ur flapper leaking boost already,check ur valve bent or not, check watever is possible, my adv is not to drive the car at all for now, fix this first before u go into bigger problems =)
mostly if turbo kong, u can drive but its hard, if shaft play got very noisy bearing grinding sound
sifu2, sila tolong
cheers bro :biggrin:
sifu2, sila tolong
Thanks bro...i tot if turbo kong there should be a white smoke from exaust..uwa....no G Force no boost only vacum....vacum seems normal...below 0.5..
---------- Post added at 12:03 PM ---------- Previous post was at 09:51 AM ----------
start the car just now...just to warmup the engine...then cek the fuel...wahhhh drop like hell....y ehh?
Write your reply...
