i beg to differ. there are quite a few skylines (that i know personally) with aftermarket turbo, cams etc running with emanage. yes it is true that all of them have standalone ecu on their wish list but in the mean time, their skylines are still running stock ecu+piggyback on daily basis without any glitches at all...10k of ecu with standard turbo wont' be much help ... but the 10k ecu can standby for future mod ... since the ecu control everything for your future mod ....if he put in a e-manage blue now ... when he come to mod to bigger turbo and injector ... the e-manage blue might not be able control it anymore ... why waste money and time on 2 times job ???
yeap. everyone's correct. it's all based on personal pref.
hmm, easily put is
motec = hks v pro + vcam systtem.
errrrr..... i wouldn't really put it that way
you can't really compare an ECU with some thing physical like the V-Cam system
The Motec M800 series can control the valve timing for engines equipped with valve timing (VTEC and whatnot) but on the RB26, you're going to need to physically install the Vcam system (which comes with a seperate controller, so you can use any ECU you like)
In the end, its just an ECU...tuning is more important, as that is what actually makes your car go (or not)
motec is roughly rm10k if you're ok with it. I'm currently using f-con v pro and i have no problem with it. like what khoyos said, better get a bigger turbo with that kinda money. A 10k ecu with standard turbos won't be much help. just my 2 cents.
Anyone tested or read on AEM EMS ... They do PnP for Skyline too these days ... :hmmmm:
bro what version ur using now? i'm planning to get f-con vpro also for my ride but the 3.3 version is still expensive and i heard the vpro 3.2 is not compatible with the new vpro 3.3
(other that ZTH off course)...
