Mivec Matspeed camshaft
galantwagon
Sold, Thank you.
Hi,
Matspeed Mivec 1st gen camshaft.
Duration 306/304.
Price:RM1500 nego.
Item belong to my friend so please call,
0123588660-Yard.
Thanks,
bro..what duration for standard cam mivec?
Low speed cam -
In Dur/lift - 228/7.58mm
Ex Dur/lift 232/8.24mm
High speed cam -
In Dur/lift - 300/10.41mm
Ex Dur/lift 285/9.83mm
I had try this similar cam before ..... fast respond from mid range to high rpm range .....
1.8 can very smooth rev until 9k rpm .....:burnout:
Thanks Catan for the info.
A good upgrade cam from Matspeed for Mivec.
Call for negotiate...
can fit mivec turbo ?
Of cz. As long as you use a 1st Gen Mivec head, this can go in.
Any idea on the idling? What about HP gains? What valve springs do you recommend? Thx.
Item Sold, Thank you.
v2peter- kevinn7 already answered your question.but from my experience,turbo dont like valve overlap.A short duration intake cam will works well with a turbo.
kevinn7-No problem with idling, still can idle under 1000rpm.Before was use with standard valve spring.
