SV4 need help
TRD.AE92
Having some problem on my Uncle car:
My uncle car is Honda Accord SV4, 2.0 SOHC (standard), and Automatic.
1. when turn the key to ready mode, the auto indicator D4 & P light was turn on but the actual gear is on P. When start the engine, the indicator D4 will be off.
2. Morning start the engine and push the gear to reverse, the car won't reverse. Unless you push it forward few time and try again, it will able to enter the reverse mode. Or else let the car heat up itself about 5 minute, then it be will able enter to reverse without any problem.
3. brake lamp indicator light on. I do check the brake pad no problem, brake servo no problem, test braking also no problem, even hand brake test also OK.
4. when compressor is start working only, it will have a funny sound come out. When it on operation or stop operation, no sound at all.
3. check your brake light, one of them could be blown or going to blow
4. compressor about time to konk
can u suggest what brand of good absorber for sv4(not adjustable or standard)?
for family car...good quality and price acceptable...
thank u..
H22A..... hehehe.... sioksiok mey...
TRD.AE92,
Prevent Is Better Than Cure....
kereta aku absober lembut la. tolong suggest.......thanks
Don't change ur suspension.. just potong the springs, leave about 3inch for each springs, take out the rear disk brake n replace it with saga rear brake drum(ni betul2 suda jadi, saya kawan sudah test sikalang kereta itu main sepang drag malam rabu). To balance the car weight distribution, remove the cataylic converter and replace it with cash converter(brand new about 74sing dollar). Now u kereta sudah stable. suda boleh main koner2 langat. saya 1 kawan pailang cakap tidak dengar masuk kereta tasik dalam. Dia pomen tune tidak ikut adat. Mr Hilmi, if anything aa i can hepch u.
Regards,
Danny
