Wira VR4 RS for sale 240 hp
nofx_nizam
Price : RM27500K NegotiableBody 1.6 XLi 1997Below are the spec in details ;Engine & Performance-VR4 RS engine-Evo 3 turbine housing-Evo 3 exhaust manifold-Mirage intake manifoldEvo 3 distributorEvo 3 InjectorComplete S/S I/C and filter to turbo piping with SAMCO silicone hosesHKS SSQV BOVTiAL 38mm wastegate complete w/downpipeFew month old maintenance free batteryOil catch tankSard fuel regulator complete setNGK Silicone Hyper plug cable1.5mm metal gasketBig double layer brake servoToyota FICDEvo 7 I/CBlitz S/S open pod filterEVO 3 radiatorSteel braided upper radiator hoseOriginal mitsubishi oil capWalbro 255LPH hi flow fuel pump4WD Fuel TankHKS Hiper exhaust with S/S piping2 PU engine mountingUse evo mounting on timing belt side instead of vr4Exterior, Body & ChassisFull bodypart from EVO 3Sparco bonet pinComplete mitsubishi 4 door w/ all side screen & mitsubishi air pressFront &Rear (w/ functional wiper) mitsubishi windscreenFront & Rear silicone wiperSingapore style plate no. holder w/ steel no. plate ‘ketuk’Original Cusco front & rear stabilizer barRear lower arm welded with plate like evo armEvo 3 front lower arm w/ evo 3 antiroll barStandard rear antiroll barTein Hi/Lo & Soft/Hard adjustable suspensionFront camber screwRear camber rod and alignment rod (Bought new)Front evo/vr4 brake set, knuckle 114.3Rear evo brake set, knuckle 114.3OZ sport rims 16"InteriorGsr doortrim front & rear complete with power window switchMomo streering, VR4 gear knob, Razo brake and fuel pedal coverEvo dashboard with climate control , center armrestRare 240km/h meter panelApexi boost meterPivot turbo timerAutometer AFR meterFront EVO 3 seatRear gsr seatGsr libero carpetOthersSteering rack set changed, with new tie rod end and silicone mountingEngine overhauled 6/08, change new piston ring n valve sealClutch pump, fuel filter changed.Spent more than RM 22k oredy for this car at this state..
http://i172.photobucket.com/albums/w14/gorillabiscuits_photo/DSC00624.jpghttp://i172.photobucket.com/albums/w14/gorillabiscuits_photo/DSC00628.jpghttp://i172.photobucket.com/albums/w14/gorillabiscuits_photo/wiravo.jpghttp://i172.photobucket.com/albums/w14/gorillabiscuits_photo/attachmentD8.jpghttp://i172.photobucket.com/albums/w14/gorillabiscuits_photo/DSC00729.jpg
no phone 019- 458 5270 nijam
location kulim & penang
