- Joined
- Mar 30, 2006
- Messages
- 64
- Points
- 1,508
Wow, full boost by 2.5k rpm ? That's what I'm looking for. Is this GT2530 turbine from HKS ? How much does it cost ?
I'm asking about the compression ratio coz mine's running 11:1 too. So if the 2ZZ is running at 11.5 have no issues with the boost, then it should work on mine too. I'm contended with 0.5/6 bar boost. So meaning no metal gasket is required to accommodate the o.5/6 bar of boost; did I get that right ?
Thanks, Barb.
I've heard of this problem you mentioned with the e-manage before. I don't mean to argue or anything but I'm using the blue e-manage on both my Toyota (BT & 3S-GE) for almost 8 mths now with no such issue:hmmmm:. I'm quite happy with the improvements made too.
I was eyeing the Power FC too but unfortunately, I couldn't afford it & besides, I think it's model specific & they do not have my model (for the redtop Beams 3S).
Power FC is a standalone, right ? Does it have any issues with the air-cond ? I've heard of some standalones having problems with their air-cond.
Thanks, Andy.
Thanks for being so helpful & patience with my questions, guys. You guys are :top:.
The problem with Emanage seems to only infect Auto 7th Generation Celica the most. Other older generations toyota seems to be ok. Power FC is a standalone ECU correct but the Brashboy PFC still needs the stock toyota ecu to control the gear changes for Auto Celica. I have been using the Brashboy PFC for more than a year now, so far no problems with my aircond.
Andy
My car got problem..
