Hayden Automatic Transmission Cooler Kit - Rapid CooL, provides the BEST Cooling among the range..
Automatic Transmission Failure is common in today's automatic transmission cars.
By adding an ATF Cooler, you can prevent the transmission oil from overheating which will SAVES it from Expensive transmission failure !!
Other benefits of adding ATF Cooler includes improves gear change responds, longer transmission fluid life span and better fuel economy due to less transmission power loss.
- Brand New Hayden ATF cooler from USA / Austrialia.
- 100% Original ( or Double your Money Back Guarantee !!! )
- Universal, suitable for all Automatic Transmission cars..
- This kit comes with the cooler, hoses, mounting hardware and installation instruction. - 33% more efficient than a comparable tube and fin design
- Pre-drilled mounting plates for easy installation
- Internal turbulation for efficient heat transfer
** Made Specifically for ATF, Not the Normal Engine Oil Cooler type that can result in Pressure Lost to your transmission !!!
** BEWARE of FAKE Hayden atf Replica from China !!!
Core Dimension :
BIG : 280mm x 150mm x 19mm ( 17 Rows - 2.0 liter and above vehicle )
SMALL : 280mm x 110mm x 19mm ( 12 Rows - Below 2.0 liter vehicle )
Price from : rm270 !!
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Rev Performance at No.7, Jln PJS 11/24, Bandar Sunway (Above Matspeed) or Send by GD Express.
CLICK HERE to check out my other sales Item !!
https://www.facebook.com/pages/Rev-Performance-Auto/194149357289701
Thanks for Viewing !!
Core Dimension :
:hmmmm:
