GAB Lower spring for AE101
Lan4ag
anybody using this brand of lower spring? how many finger from arch to tyre??
i once used GAB with Monroe Sensatrac...2 fingers front n back
I would like to ask , lower spring means..remaining the suspension ( the rod )..Don't know what izzit call..and just change the spring in the suspension ??..
thanks Kayy, 2 finger only. but Kayy is it feel soft or hard? now i using Gab Absber with lower spring "ayam brand" its very lowered and soft, even 1 finger cant put into the arch, then i chock it with rubber bushed to make it up little bit, but still feel soft. anybody can help?:confused::confused:
it depends on the spring weight...the higher the weight, the hard u will feel....
if u like hard suspension...u can try Tein, TRD springs...
just my 2 cents.
Bump: it depends on the spring weight...the higher the weight, the hard u will feel....
just my 2 cents.
its comfort...not too soft...cos monroe is a progressive absorber with big shaft..
absorber gap SA AVCS wif gap spring also comfort
lowered 2 finger ...nice
thanks tamok for da info..ya Gab SA Avcs is brand new n M'sia Made, suitable for Msia road..
especially at Tawau,here the road surface is very bad, even at the town area have many hole..:bawling:
for my experience, it's 2.5 finger (4.5cm) front from the arch and 1.5 finger (3cm) at the rear.
please bare in mind that both GAB and his brother DR.Spring is Sport Spring not lower spring, though it does lower your car's ride high. they had higher spring rate than original spring, so it would give stiffer ride.
ist true fren? i just buy it Yesterday,but not yet install..maybe i try it first..thanks:confused:
soft or hard is depend on how u defined it .. (sendiri rasa)
maybe i feel soft on my current setting, but others said hard ..
currently i'm using Apexi soft/hard adjustable ..
i bought around Rm4++, now i already install it to my Seg,the lower is 2 finger front n rear, the feeling is very comfort, i like it.
