- Joined
- Nov 13, 2007
- Messages
- 660
- Points
- 1,518
if 4g61 with vr4 piston how many hp bro?? heheheheh
waste of money laa bro,rebore how much?piston how much?labour how much? sum all = vr4 engine kosong oredi...heheh racun..racun..racun hahahaha
its...under progress lor..huhu
will info u the result...![]()
& u have to keep that vr4 as a spare for a long time... hahaha...
*not settle yet the endorsement...![]()
go for vr4 terus la enche mell...![]()
stick with ur 67 block,just rebore,if got budget go for forged pistons,sum cams,wallaaaauuwweee..ur car laju oredi
64=2.4![]()
oil pump use back laa 67,oil squirter no need,gearbox use back, he's only got 10K so that's about it.Proven already that recipe ok for his budget.67 gearbox ratio longer abit.Stick with it bro.hey it's just my 2 cents.Up to it's your money
having to say that i'm also usin 67 block with 87mm bore and 93mm strokes lifting..
still drivin healthily for almost two years..
guess even 67 block can also be fit with this 2.4 liter stroker kits
but in my humble opinion..there're many other restriction when u already have a very high compression in ur block
the reason why toda, jun or even HKS produce a limitation of 2.3L after market stroker kits for 63T![]()
hi, yopo, for the 93mm conrod, can be fitted on a standard 4g67 crank??
as i know the stock crank only support 88mm...
which car's crank & conrod u source it from?
