20v bt adjustable cam pulley
20V Quard Cam
Hi everyone, is 20V auto bt suitable fix the adjustable cam pulley?
So, if installed liao the vvt will be disable?
Fuel consumption how?
is there any adjustable pully out there for 20V intake cam? (other than TODA and TOMEI's adjustable pully) got picture?? which brand you were using?
yeah..they custom made 1 following toda design:biggrin::biggrin:
tuning??????need 2 tune wat?? ecu ? or jz de cam pulley?
cuz thinking of install one ma..
haha
but mine is auto wor...got effect?
u need to adjust the pulley to get the prefered timing....if u dont wanna adjust it, better use the original..hehehehe..err ur ecu can tune ha?
because he try to get some kick...hehe
well yeah but changing to adj cam pulley wont give u a kick..better change to super hard 3puck ceramic copper power clutch set..
sure kicking kaw2 :D
hahaha.. i think his leg will patah if stuck in jam... :rofl:
toda cam pulley + toda hicam + toda valve spring = kick
toda cam pulley + toda hicam + toda valve spring + racing clutch = extra kick
but after change both campulley,i think better to upgrade hicam..
unless u change ezhaust campulley only..but the vvt still enable laa..hhe
toda cam pulley + toda hicam + toda valve spring + racing clutch + oversize piston + ecu = kickest!!
hahaha:stupid:
toda cam pulley + toda hicam + toda valve spring + racing clutch + oversize piston + ecu =kickest!!
toda cam pulley + toda hicam + toda valve spring + racing clutch + oversize piston + ecu +12K balancing + TRD forge piston-con-rod-crank = Broke!!!
:biggrin::biggrin::biggrin:
