WTS : Matspeed J5 ecu for 4G92/93 SOCH
AvexTrax
Bangi/PandanJY
1 unit of Matspeed J5 ecu for 4G92/93 SOHC for sale
Previously used of 4G92 SOHC
Reason for sale Owner Upgraded to Microtech Standalone
ECU specs :
Fully remapped for track use
REVcut 8000rpm
Speedcut removed
GREAT condition ECU and can increase ur 92/93 SOHC performance
RM850 SOLD!!!
Interested PM me @ call @ sms 0199478200
Items at Pandan Jaya for Viewing
mind asking what code for this ecu ? not for me but for my friend...
yup, code series important too, there are 3 type ECU can use which one from perdana single cam, 1.8 SOHC, and 1.6 SOHC...
izzit compatible if the engine just stock engine and this ECU mapping for track car setting?
When got the car..the serial no was already missing
was used previously on 1.6 SOHC
It was compatible before as it was used on 1.6 SOHC standard engine
bros...
1.8 sohc JDM only can put chip... ecu number is 7781
The
Forgot to mention... if was properly modified then can be used in local
1.6 SOHC.... if not only 2 injectors working only....
Another thing... if you have high cam... 8000rpm would not be sufficient.
Anyway if need to up your rpm cut, pls PM me....
bros...
The
Thanx for the info bro
why only 2 injector working when not tune properly?
btw the previous engine used this ecu was a 1.6 sohc engine and running fine
the sale was due to the owner changing to standalone for rally
will call u if need the service
thanx again
AvexTrax...
If you see inside the 7781, you will notice it has only 2 standing power transistor/IC for the injectors... Local ecu have 4 of those IC to work 4 injectors.... Some addition mods need to be done to the 7781...
The J5 chip comes with a small board also correct. Have see 1 on my friend's ride..
