knocking why?
naklaju
Rawang
1)What CAS (cam angle sensor) function?
2)Why when the cas sensor is in normal condition (normal = middle)my
knocking hi (150) when accelerate (tarik pick up= floor throtle )above 3k
rpm.
3)When i turn the cas sensor to max (clock wise) the knocking is minimal
(max =8)acceptable for me... :D
4)If the cas sensor set to max ,is it will cause coil to dead...one of my coil
pack dead(melt)..and next coming another one likely to have symptom to be dead.
engine rb25det
m35i hks spark plug
stock coil pack..
It's to control your ignition timing. The default stock settings is to set it to 15 BTDC @ 650RPM. You can set it with a timing light or a consult interface. The positioning of the sensor differ from cars to cars. You should get it adjusted/tune to the original settings. Do not meddle with it as it can kill your engine pretty easily. hehe.
the cas is set by my tuner when i install pfc..i just curious..so i adjust it to normal and test...suprise me the knock is hi on the pfc com..so i adjust back to max..
very limited one...got the unit from n1..the 2nd last one..now finish...at japan auction 82000yen without shipment,commision,tax...very expensive now...but plan to take e11v2 after this...heheheh
ur car is not compatible with pfc as urs are converted manual ... e11v2 should be fine
sell the pfc to meeeeeee ... hehehehehe
how much market price for pfc??? got one with my unmovvable car... maybe i'll sell when i got an engine to swap with the current one..
r34 RB25 NEO VERY difficult to find now even in japan...u have pfc on ur r33 ek eleh? r u using neo engine pfc?
u interest with the pfc innocete?
Pls read the manual properly for the PFC, get it dyno tune with the proper A/F. It works on auto convert to manual, just that TCS will not work.
Nice to see, nice to touch but once to set them wrongly...kabooom!
Just my 2 cent of advice.
its already on the road tune..yes tcs not function..it just make me feel wierd why my cas was set to max by my tuner..i my self adjust it to see what happen if it at normal place..:biggrin:..afraid wiil melt another coilpack...just to confirm will not melt splitfire after this..when i see the knock rise to 150 when floor it ..i just release the pedal..(jahax response was fast still cant catch him)...:biggrin:
1bar with knock = 8 - 12 max..
wiring loom for rb25det ...rb26 pfc to rb20/25 engine...but not rb25detneo
http://www.skylinesaustralia.com/forums/Rb26-Pfc-Working-Rb20-rb-t161511.html
its already on the road tune..yes tcs not function..it just make me feel wierd why my cas was set to max by my tuner..i my self adjust it to see what happen if it at normal place..:biggrin:..afraid wiil melt another coilpack(splitfire already in the boot)just to confirm will not melt my splitfire after this..when i see the knock rise to 150 when floor it ..i just release the pedal..(jahax response was fast still cant catch him)...:biggrin:
1bar with t04r with knock = 8 - 12 max..
150 knock levels is super dangerous. Better check with ur tuner on this. Mine is always around the 10-20 range even on full WOT. How does the T04R feels like on the RB25? Any cams?
T04r a bit laggy..but when the boost comes in, u can feel ur rear wheel spin...t04r need 1.5bar boost to feel the G's..
T04r a bit laggy..but when the boost comes in, u can feel ur rear wheel spin...t04r need 1.5bar boost to feel the G's..and just pon cam ..
I can imagine the power going thru the wheels at 1.5bar. Im also running at that range but a different turbo, 3rd gear wheel spin is the norm...weeeeee!
Btw better sort out the knock level, don't advice ur CAS to be at max. Im not tehno savy when it comes to PFC but my other mates are so well verse that they even bought the software and tune it themselves with a wideband installed.
Hope u get ur ride sorted.
my car kene pecah already....no knocking anymore..sakit kepala now....shit this thief.....will kill this bastard if i found...:mad::mad::mad::mad:
Kasi bunuh je pencuri tu!!! They dont think twice when stealing ppl's hard earned cash / items... why do we need to even bother having mercy on them.. problem is.. in our country's current situation.. things only gonna get worse.. the economic situation is getting worse..
