[After12] Myvi Performance Parts.(AXT,UR,Hotbits,MYTHELOGY,ETC)
MAX_TorQue
Welcome to AfterTwelve E-Garage!!!
All products are brand new.
We do shipping internationally / COD / Credit card accepted.
We provide installation as well.
Some products quoted including installation.Please take note.
Click to visit: AfterTwelve E-Garage ~Please click~~Please click~~Please click~
For order/enquiry, please contact JACK 012.312.7113.
Location: Bandar Sunway.(Same row with LINKS power, or just behind JC Asia / Hup soon tyres)
Myvi Radiator Hose RM340
-All hoses are silicone rubber construction with smooth wipe down finish.
-Temperature range -50°C to 220°C.
-Thickness = 5mm with four mesh Polyester or Nomex layers to enable high pressure than original rubber hose does.
http://i265.photobucket.com/albums/ii226/after12motorsports/WORKS/ae12338c.jpg
Myvi Magnectic oil sump nut RM35
-High quality Magnetic Oil Sump Nut to catch any metal particles in your engine oil,keeping your engine completely free of metal bits and shavings.
http://i265.photobucket.com/albums/ii226/after12motorsports/WORKS/1651357c.jpg
Lightened Crank Pulley
Material:
AA6061 T6 aluminum alloy
Function:
-Lightening reduces rotation mass and moment of inertia for easier acceleration.
-Undersizing changes the ratio between the crank and the accessory pulleys, reducing the load on the engine exerted by the accessories
**Tested and proven with no vibration, extra noise, and belt safe.
Package with installation RM380
-Wira OEM rotor with ventilated design
-Cone and spacer
-Plug and play
Benefits of getting this package:
-Rotor size is slighty bigger compare to myvi OEM rotor.Better braking.
-Ventilated design to improve performance and cooling purpose.
-No need to change brake pad.*Unless brake pad finish.
-No need to change caliper.Plug and play basic.
-No need to upgrage bigger size rims just to clear bigger size of rotor / caliper.
Full set:
Spacer and cone:
Ventilated design:
Customer Car:
AXT Front Rotor for MYVI RM299 Last set!!!
Installation charge (Change rotor and pad) : RM50
Hotbits Full Stainless Steel Exhaust System
-For more information pls click HERE.
Hotbits Full Set Exhaust System:
Extractor RM340 + Mid section RM320 + Rear section RM340 + Labour F.O.C. = RM1000
*Promotion with Purchase and Purchase: Add RM99 for Firihill Thermal Bandage wrapping on extractor.
Hotbits Extractor 4-1 design RM340
-HB.EM 85-400-S-SS
-All pipes are equal lengths and mandrel bent.
-Dyno-tuned for maximum engine power gains.
-Bolt-on directly to the corresponding Hot Bits Exhaust System.
Hotbits Exhaust System
-Mid section HB.ES 85-500M RM320
-Rear section HB.ES 85-500R RM340
-All mandrel bends for maximum gas flow with-out any restrictions.
-Low-note sporty exhaust sound, maximum sound level 78 decibels.
-Aluminised steel pipes and mufflers or 304 stainless steel (part no. with -SS)
-Direct bolt-on exhaust system to the corresponding Hot Bits extractors.
Supercircuit Exhaust system
Extractor 4-2-1 Stainless steel Extarctor RM450
-Equal length desinged and quality workmanship
-Dyno tuned design to improve maximum engine power.
-1 (ONE) year warranty at leaking / crack.
Full Stainless Steel Catback System RM980
-Single exhaust tip design to suit mostly OME / aftermarket skirting or bodykit.Plug and play.
-Quality workmanship and mandrel bent piping.
Dyno Result:
Customer Car:
Ultra Racing Products
Front Struct Bar 2p
Fender Bar 3p
Rear Struct Bar 4p
Room Bar
Anti Roll 16mm
Anti Roll 19mm
Anti Roll 23mm (Myvi 1.0)
Lower Arm 4p
Rear Lower Arm 2p
Side Bar 4p
Myvi Latest Fibre or Original Bodykit:
Pls click to visit: AfterTwelve E-Garage
(Too much to list down here.)
bro just 1 2 ask about the RSR spring for myvi, what model is that? Down spring or Ti2000?:hmmmm:
Thanks bro.
We provide installation and painting as well.
Some item's price quoted below including installation or painting.Please take note.
Any kit that you are interested but not listed here, please contact us.
Please CLICK to VISIT: AfterTwelve E-Garage
may i ask something?
my myvi auto1.3
i;ve modified 4-1,2"piping,using 2 marco bob,warlbro fuel regulator,greddy plug,air filter changed
whats next to make my car go fastER? pls let me know at 0167155539 thanks
