BT engine mounting
20V Quard Cam
my auto blacktop engine mounting kong i guess.y?
cz whn i from 60-70kmh pull to "2" the engine vibrate,whn from 40kmh pull to "L" lagi worse,engine like wan drop from car.
isit I alwiz pull to "2" so the mounting kong?
or jz auto have this problem?
and if i revv kao kao,i can smell some duno wat kinda smell from engine bay inside de car.vry smelly.like the machine over revving smell,i guess lar.
till 8k rpm i revv nia.
anyone can help me solve my problem?the mounting if i dwn repair 1st will affect anything?
firstly, check your ATF level and condition first.
see if it's dirty. for BT's auto gb, and u got do some high revving,
it's recommended u to change the ATF earlier than the suggested mileage.
and along with that check all oil seals and also other oils (engine oil, p/steering oil) also.
another suggestion, maybe u can consider installing a ATF Cooler to your Auto gb.
just my 2 cents.
ATF is?auto transmission fluid?
anyway,i ady add a cooler to cool the gearbox.i took it from pajero one,diy myself =)
just my 2 cents.
my question. what do u mean ATF cooler? isit like GB oil treatment?
ATF = Automatic Transmission Fluid
ATF cooler = it is not oil treatment.. it is like oil cooler. err.. it's like a small radiator/intercooler.
Quoted below
"The #1 cause of automatic transmission failures is overheated transmission fluid. Today's cars generate extremely high under-the-hood temperatures. Add to that the heat generated by an automatic transmission, and you'll see why adding an auxiliary transmission oil cooler is a must for guarding against costly transmission repair.
Automatic transmission fluid cools, lubricates and cleans transmission components. A transmission cooler is basically an auxiliary radiator that provides extra cooling for automatic transmission fluid. When transmission temperatures exceed 200° F, transmission fluid is strained to its limit. Overheated fluid won't properly protect transmission seals and moving parts. When oil temperatures exceed 200° F, oil breaks down, causing seals to crack and leaks to occur.
It's a small investment now that can save you on repair bills later. With each 20 degree drop in operating temperture, your oil and equipment life doubles. By reducing your transmission oil temperture as much as 60 degrees, a Hayden transmission oil cooler can greatly extend the life of your transmission.
Hayden ATF cooler.. (if u got money, get this) http://www.odyclub.com/images/kit.jpg
http://www.motorexonline.com/images/ATF%20Cooler%20%28high%20res%29.jpg
if u got tide budget, u can get a used oil cooler from old pajero/4x4, wash it clean and then get some hoses and connector and installed it as ATF cooler also. (u can go DAWS, danny knows how to do it)
My car using ST, so I'm interested to install oil cooler by myself, can you give more detail explanation and pictures included if have it, more easy to understand.
Reason : Always have long journey, so more cooler the temp get, less petrol per mileage I get.
Diagram
https://www.zerotohundred.com/forums/attachments/128599.vB
* if the image unable to be displayed properly, please click it to pop-up another window to view.
ATF cooler installation link
http://www.tundrasolutions.com/forums/engine-and-drivetrain/66360-transmission-cooler-installation-how-to-guide/
Oil cooler installation link
http://wiki.r31skylineclub.com/index.php?title=Engine_oil_cooler_-Installation
* do a search on the internet, there are plenty of info there.
