[need help]Steering problem!!!
speedmax2001
my car is ae80 running wif 4agze from ae101 halfcut..the problem is my sterring when i turning right it can turn about 2 half round, left only 1++ round only! y the steering is not balance?anyone got exp about tis?Any sifu here can help?
can u explain more details...u mean the turning ratio?
have you try alignment or get opinion from foreman?
oledy do alignment...still the same!! the foreman oso dunno wat problem!!! who hv tis kind of prob b4???
owhhh.... unbalance turning radius, hav u check ur steering bolt-head? ur steering rod (dat got tread n attached wif tie-rod-end)? check which side is longer n which side is shorter? then cut them n make new tread ler 2 rebalance it :-)....... if u r using complete ae101 steering rack laa, coz dis modification job required a good foreman who knows (very well) bout toyota engn conversion, juz my 2cents, sorry my english is bad, dunno how 2 translate it into words :-)......
turning ratio tak sangkut wit alignment...u go tire shop and ask them balance bak ur turning ration....
if last time dun have tis problems now have then i also dun know ...
but if u after convert or change rack then just go balance bak the turning ratio..
iszzit u mean wana custom make new tread it from engineering??anyway thx ur comment!!!
