used Power FC GTR33 D'jetro
aibon
Dj
power FC GTR33 D'jetro without commander!
comes with 2map sensor
asking for Rm3800nego:_: :_:
016 233 9115
Bro,
The powerFC in the 33and 34 should be the same or is this specifically for the 33 only?
This is DJETRO version
different from normal Power FC le
cmng: Thanks for the explanation.
Btw, just for understanding sake, is there any disadvantage of using the AFM PowerFC when chasing high power?
You can always swap up to a bigger AFM like the RB20DET or the VG30DET one..
Plus there are alot of 800 - 100hp skylines in aus using this computer but locally, F-Con seems to be the craze?
Or if it must be powerFC, at least the Djethro version?
Thankss again..
can someone explain me whats djetro and whats the differ...
sorry for being noob.. my 1st time heard that..
powerFC uses AFM's.
Djethro version uses Map sensor.
Map sensor is similar to the F-Con vpro..
AFM same as standard computer.
powerFC uses AFM's.
coright kenny san.....
and the best part is ,NO wring just replace the ori ECU!:_: :_: :_:
but for the D'jetro u need to set up the map sensor...tats all....:X-:
you can use back MAF at FCON V pro
for FCON V pro MAP sensor is optional
Yea but i was wondering what the advantages of using a Map sensor as opposed to just getting a larger AFM?
