WTA:rimm offset...
slj
kk
GUys,
Ccan 18x8.5 +22 fit in evo8 without rolling the fender.....anyone had tat one their ride??? any rubber rubbing ??? wht tires size ......
how bout 18x9.5 +22....possible???
THank.!
if not too low means high lo.. but if use such a big rim, i dont think making the car higher look nice.
what makes u to get such a wide rim with this offset?
ic. how much u got the rear fender?
i think for the front, there should not be a problem since the front is 20mm wider.
but for the rear i heard need to cut the inside if not the car will be very ugly.
i also order the rear fender, should arrived next 2 weeks, but havent conform the price should be around 3.2k
i also have such a problem for my rear fender. i am using 18 x 9.5 + 35 its matching with the ori fender now. when i got the fender, i plan got use a 10-20mm spacer to make it look nice, but still not sure about the height.
now current setup is 1 finger front and rear, but my rear need to flip inside. using 245 tyre. c how la have to try first only know. may be adjust the damping rate to the max.
hahahaha......still consider to put the rear fender in or not.... coz been confusing bout the rear ..... feel very troublesome if wanna touch on the fender modification.....i got the front pair already...rear...quoted from JonDemand...usd820 included shipping ....and maybe now waiting for replica see lo...
but if use spacer...dont it look kinda ugly and danger.......
anyway, pls share share ur pic and info after u install the rear fender..ok bro...??
wat i miss here woh ??? wei, you 2 ci bai borrow me $$$ to upgrade my car la.... change wat rim or fender ??? hahahahahaaaa
ho,
how's the bride gias woh ??? getting it ar ??
and you buying eibach spacer ar ???
seng,
when you coming kl ?? we go kau lui.. heheheee
btw, you know racheal and candy from kk ar ???
rachel wat oh......how look like...... candy...who again oh....ui not geng kau lui like u man...u din teach me la...cheww.....who oh who oh......u ask they know me or not lo..hahahaha...if don know me.then ..sure i don know them too..LOL
Hey guys,
Since u guys talking bout rims offset, is it ok for ur car to use tyre spacer? I mean is it ok during highspeeding or cornering?
BLADE888,
depends How good is ur spacer...have to consider the material used ....the screw..and etc
ic, how about if using different pcd where from 114 to 100. One side 114 and another side 100.
hahaha.. just remembered them from kk also.. if i go kk sure will 'kai siew' to you one.. hehehehe.. airasia got promo.. ..
blade888 ,
wht the point for using different pcd. ?? unless u got 2 set ur diferent rim... but is ok also if u wish to...no big deal...
Stopid,
when coming oh...hahaha...i also know a rachel....is she stedwardess ah??? hehehe..
820 is cheaper, and is that including us tax and malaysia tax as well? i been calling JD once when i am at us regaring voltex item, normally that ppl dont keep stock, if u want they only ship from japan to us normally take 1 month time.
regarding the spacer, u can get the hi quality aluminium racing spacer. it comes with 5 additional stud. normally can get those from halfcut.
Hey guys,
u can custom made aluminium spacer and try to avid getting those ready made spacer from tyre shop which have lots of hole, u will shake like hell if u put in front.
