Exhaust system Spec - Evo7
zareef
Sifus,
Kindly enough to share the set up u having and what is the best specification, no modification on engine. custom or branded HKS, APEXI, Greddy etc
Appreciate the suggestions and reccomendations. TQ
Myself using HKS Silent HiPower... Result quite satisfaction, increase mid-end power n pretty quiet which jus suit my preference...
Actually exhuast r pretty much same for various brand, except u wanna it made in Titanium (Trust Ti, HKS Ti Spec R) so tht its very much lighter in weight or u aiming for a loud noisy type of exhuast (5 Zigen, HKS Super Dragger)... As for HP increase wise, it really depends on what other thingy u hv in ur car...
:_:
Thanks guys,
Better get the complete exhaust system. Where to bargain? N1 and Wangan i guess.. Any other place to recommend?
soundstream,
once you've changed your exaust system.. it's better to change your down pipe together...
brother.. you busy lately ah? long time no hear from you lah!! hehehe
zareef,
Try SS Racing along Old Klang Road lo... Price can b very attractive sometimes!!! Hehe... They hv de Tomei manifold, 'turbo outlet with Front pipe package' + few brands exhuast for Evos la... Abt price ah, i forgot lo.... Got to go try ur luck la...
Cheers!!!
zareef,
Cheers!!!
S9, tomei manifold pakage dun have wategate one rite? My friend installed, i think he paying RM4k+ for that, not sure.. but sure looks nice. Onli thing is it doesn't have wastegate cause I kinda like the wastegate sound.. keke
wastgate TIAL mana model is recommended for a 350-400bhp ?
aso any good recommendation for better grade (quality) manifold (with wastgate connector) ?
any opinion ?
Thanks Storm,
been piling $$ for sometime now.. hope enough haha.. to be frank i have no idea what to upgrade after the exhaust.. looking at n1 website.. felt like.. need to spend 5 figure to be at medium level.. always kena tinggal with small2 car.. sigh
Does a standard 280hp car mean it is already powerful?? i dont think so with my
E7.. i think my car heavy laaa..
manifold and waste gate upgrade.. can it be used with standard TD05? or need turbine to be upgrade as well?
aso any good recommendation for a good (no crack) manifold (with wastgate connector) ?
any opinion ?
i know a few evo "monster" is using Tial 44mm of 1bar spring rate. of cuz u can ask for different spring rate of 1.2 or 1.4 etc.. personally i also prefer 44mm, should be good enough n it look much better than 46mm la.. 50mm i think is abit over kill :P
for a cheaper solution, manifold u may potong ur ori and customize the connector n wastegate pipe.. or complete customize the manifold itself too... if got budget, go for complete aftermarket manifold with wastegate outlet...
as for as i know, cracking is a matter of time only no matter what kind of manifold u hv.. (except the ori casting la) :) my aftermarket manifold was rewelded twise already :P
LanEvo,
Yep, i dun think Tomei hv manifold for wastegate... But HKS do hv it!!! Come in a package together with de wastegate... Ur fren buy which model of Tomei Manifold? So damn exp. for rm4k+??? Wow... Tht's killing man... haha...
Zareef,
Normally stock std Evo dun not need a wastegate... Ori actuator wil b enough for stabilising de turbo boost unless a new actuator is needed when de old 1 spring rate hving problem... If u change to bigger turbo, then there r packages which including de wastegate too...
Normally for stage 1 upgarde, v do de Air filter, full exhuast system (manifold, turbo outlet, front pipi, de-car n exhuast), pipings (intercooler / radiator), all kinda electronics meters for monitoring, all kinda strengthening bars, ECU, suspension, Racing clutch n etc... Depends on what u wanna for ur car... So for ur case, mayb try air filter n full exhuast system 1st... Then a boost controller, Racing clutch n an ECU wil do... Hehe... Jus my 2 cents! :_: and Yep, tht 5 figures thingy actually doesnt contribute much!!! Haha...
LanEvo,
S9, he bought it with the manifold + outlet + d/p + heat shield. Rm4K+ i think around there la since outlet + d/p already 1-2k+ ma.
HKS? I tot HKS one comes with turbo and intake also? Wonder whether they have just the manifold + wastegate + outlet + d/p.
LanEvo,
Yep, HKS did sell de manifold + wastegate in seperate package!!! They do hv de outlet + front pipe package too... I saw all this from Jap mag. la... Sure got!!!
Oh, no wonder la... U r adding up de turbo outlet + front pipe together with de Tomei manifold... Haha... Yeah, then it shld comes up to rm4k+...
Wastegate me not so familiar with cos i dun hv 1 with me in my car... Haha... But if u wanna to install 1 make sure its a reliable 1... Cos it stabilize de boost where if it fail ur engine wil 'Booooooooommmm...' Yeah, check de spring rate!!! :_:
don't forget to upgrade the turbo elbow (or turbo outlet / up-pipe) while you're on it. it'll greatly improve your exhaust flow...
LanEvo,
Ic. I tot they onli sell turbo kit.
1) any chance the package only come with manifold (w wasgate) + d/p ?
2) any shop recommend to get this package ?
1. Manifold with wastegate n turbo outlet with front pipe r 2 diff package!!! Unless u buy it all seperately...
2. As usual, go try ur luck at SS Racing, N1, KSP n few other shops in Sunway lo... Sometimes see them got it, but not sure they r sold or not... Or b4 going, call up n ask 1st! :_:
