B16B using B18Cr Block!
bagas
to all honda sifus...need advise here!
what need to change if wanna to upgrade to B18Cr block?!or just simply plug n play using all B16b parts?
TQ!
very pening la the question...
is it u want to stroke up the b16b to bcome b18c or wanna change the b16b block straight to b18cr block?
Eh.. then become destrokerlah.. B16b stroke only 77.4mm (according to a friend). I think it's in the region of 80mm-85mm? lower than B18c, but higher than B16A?
But it could be 77.4mm with longer than B16A rods, since the last time in B16b.. low end torque.. aiyoh!!..
You know the actual stroke?
i think he wanna change the whole block.
should b no problem izit?
then no problem lah...just swap the block in....all other things can be used back including the head gasket if it is still ok....
its 77.4mm
if stret to change the block shud be no problem. but better change the ecu as well to get the right setting for the engine.
hih hih hihh.....dats y i'm ask him wat happend to his block???? muee hee hee hee.....where's my previous crank ehhhhh?????
TQ!
For what reason u wanna change ??
my block still ok..no problem at all...just planning someday might go to plug 1.8 block if have 18cr block...never think about b20b hehe...
