Fixed New Thread missing Editor: Hi Everyone, the issue with posting a new thread or a reply that shows a missing editor has been fixed. More updates to the forums will be added on in the coming days, we apologize for the inconveniece this has caused
Zth member,i would like to ask wht i need to buy then can bolt on turbo into putra engine...wht is the cost to bolt on turbo into putra engine..wht i stuff i need so can safely plug n play for putra engine..
if u can find 93t Turbo kits.. Turbine,extractor,I.cooler,injector +SAFC.. such would do it.. but i advised u change the head gasket n low com pistons just to be safe..
proton do sell ems turbo kit for 4g93 Na for GTi,putra n wira 1.8... u can try that.. but a bit costly..
Hey bro.. mine is correct wht..:regular_smile:
He wanna to BOT ma.. so the best way is to rojak it with gsr turbo lor..
Hei bro 7D,
If u wanna to make a monster wise will be different talk already..
For Plug and Play..
- Mivec Head
- GSR TD04 Turbo Kit
- Supercharged Piston
- Independent ECU
- Waste gate 46mm
So.. it will be more to monster liao..correct me if i m wrong...hahhahahah...
The sporty coupe you see in the sketch above was revealed by an inside Subaru source and it depicts the Japanese carmaker’s forthcoming rear-wheel drive coupe that is...
