Dear Fellow Car Members,
We like to Introduce to you our Latest Zaptor Silver Edition II Retailing at only RM50.00. Free Installation is Provided within the Klang Valley Area.
If you need further details, please contact us at 016-3808883.
HERE ARE SOME OF THE BENEFITS OF INSTALLING A ZAPTOR VOLTAGE STABILISER...
TO IMPROVE THE CAR'S ENGINE PERFORMANCE, THE CAR'S ECU IS HIGHLY DEPENDENT ON ALL THE SENSORS THAT PROVIDE DATA SIGNALS TO COORDINATE DIFFERENT PARTS OF THE CAR. THE ECU WILL PERFORM BEST, WHEN IT RECEIVES AN ACCURATE AND STABLE ELECTRICAL SIGNAL. HENCE AN ACCURATE & STABLE ELECTRICAL SUPPLY WILL ENSURE BEST TORQUE & RESPONSE.
INSTALLING THE VOLTAGE STABILIZER WILL ENSURE IMPROVED POWER RANGE RPM, TORQUE & IMPROVED ACCELERATION. IT ALSO ENHANCES THE AUDIO, LAMPS & ALL OTHER EQUIPMENTS TO THEIR MAXIMUM POTENTIAL.
BENEFITS:
THIS SYSTEM CAN FILTER OUT ELECTRICAL NOISE & ELIMINATE IRREGULAR CURRENT FLOW IN THE CAR ELECTRICAL SYSTEM.
ITS SO EASY TO INSTALL, JUST CONNECT THE RED WIRE TO BATTERY POSITIVE & BLACK WIRE TO BATTERY NEGATIVE.
http://zaptor.webs.com/
BENEFITS:
- INCREASES TORQUE
- IMPROVES FUEL ECONOMY
- IMPROVES ENGINE RESPONSE
- STABILIZES IDLING
- EASIER ENGINE START
- LESSER ENGINE NOISE
- INCREASES HEADLIGHT BRIGHTNESS
- IMPROVES BATTERY LIFE & AUDIO QUALITY
