- Mar 29, 2006
- 939
- 2
- 1,518
Item(s):
With its super efficient Class-BD circuit topology, the P1000-1bd assures maximum BOOM for your buck! Due to its dedicated low frequency response, this amplifier is optimized for mid-bass speakers or subwoofers only. No need to worry because its 1-ohm capability will drive a pair of 4-ohm DVC subwoofers or quad-configuration of 2-ohm DVC subwoofers with ease.
Rockford Fosgate Punch P1000-1bd
1000W RMS, Punch Series Compact Class BD Monoblock Amplifier
Punch Series Monoblock Class BD Car Amplifier
RMS Power Rating:
4 ohms: 250 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
1 ohm: 1000 watts x 1 chan.
MOSFET power supply
Remote bass level input (remote level control sold separately)
LED power, thermal, and protect indicators
Tuned Bass EQ (0-18 dB bass boost at 45 Hz or 0-12 dB bass boost at 12 kHz depending on crossover selection)
On-board differential inputs eliminates noise picked up by the signal cable
2/1 channel operation
Integrated Trans•ana technology simplifies the signal path of the amplifier allowing the signal to travel through the amplifier at a lower voltage. The result is greater reliability and exceptional sound quality.
RCA Pass-thru outputs
Featured custom designed TO-247 MOSFETs have 60% more metal tab area providing more power handling capacity, lower impedance and improved heat dissipation over traditional TO-220 MOSFETs found in most competitor's amps.
Built in NOMAD is a "real time" analog computer that protects your amplifier from shorting speaker wires and dangerously low speaker impedances.
Cast aluminum heatsink evenly distributes excess heat across entire amplifier heatsink
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (50-500 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-250 Hz
Dimensions: 14.375"L x 7.625"W x 2.25"H
Price: SOLD
Dealing method: COD or Post via Courier Service add RM 25.00
Location of seller: Pandan Indah / TESCO Ampang
Contact method/details: PM/SMS/CALL
Age of item:
Condition ok. Used around 1-2 years. Can Crazy Punch if you like SPL sound...!!!
Picture:
Reference's: Rockford Fosgate Punch Monoblock P1000-1bd
RMS Power Rating:
MOSFET power supply
Price: SOLD
Age of item:
Picture:
