- Oct 14, 2008
- 1,915
- 3
- 1,638
Monster Cable is a leading manufacturer of high performance cables that connect audio and video components for home, car and professional applications. Monster Cable was founded in 1979 by Noel Lee, who developed a high performance speaker cable, named it Monster Cable, and literally created a new product that revolutionized the audio market. Monster's audio cables increase the clarity, dynamics and power of the audio signals that travel through them. Monster Cable is an indispensable component for music lovers, audiophiles, recording studios, sound professionals, musicians, custom-installers and home theater enthusiasts.
Installing an audio system on your car and don't want to sacrifice high-end sound? These RCA interconnect cables from Monster are designed to perform every bit as well as their land-based counterparts, delivering clean, uncolored signal to all of your car audio components.
Monster starts with shielded, noise-rejecting wire — specially wound to provide time-corrected, accurate reproduction — and caps it off with 24-karat gold connectors. The sealed cables resist corrosion and Monster's turbine-design connectors grip tight so the cable won't vibrate loose over time.
With audio cables from Monster, you'll get crisp, clean performance that will stand up to the rigors of life. Lifetime warranty.
Item(s): BRAND NEW MONSTER CABLE CAR RCA AUDIO GOLD PLATED WITH REMOTE TURN-ON WIRE INTERCONNECT RCA CABLE.
Package includes: BRAND NEW MONSTER RCA CABLE IN FACTORY SEALED BOX
Price: RM150/-- for 5 Meters
RM120/-- for 3 Meters
RM80/-- for 1 Meters
Dealing method: POSTAGE ONLY!!! (BUYER BEARS POSTAGE COST)...STRICTLY NO COD
Peninsular Malaysia - RM10
Sabah/Sarawak - RM15
Contact method/details: 012-21 363 07 / 016-351 3337
Age of item: BRAND NEW & SEALED
Item(s) conditions: ITEMS ARE IMPORTED FROM USA. THE QUALITY ARE PERFECT AND MINT.
Picture: AS PER ATTACHED
PRODUCT DESCRIPTION:
. HIGH DESITY SPIRAL WOUND COPPER SHIELDING PROTECTS AGAINST OUTSIDE INTERFERENCE
. COMPACT SIDE -BY-SIDE CONSTRUCTION WITH REMOTE TURN ON WIRE FOR EASY INSTALLATION OF LEFT AND RIGHT CHANNELS
. 24K GOLD CONTACT MOLDED RCA CONNECTOR WITH HEAVY-DUTY MOLDED RUBER GRIP
. FLEXIBLE DURAFLEX PROTECTIVE JACKET
Item(s): BRAND NEW MONSTER CABLE MONSTER BASS XLN 100 'XTRA LOW NOISE' SUBWOOFER CABLE WITH PATENTED MAGNETIC FLUX TUBE CONSTRUCTION 2.5 METER
Package includes: 2.5 METER MONSTER BLUE & CLEAR TWISTED MONSTER BASS XLN 100 'XTRA LOW NOISE' SUBWOOFER CABLE
Price: RM120/--
Peninsular Malaysia - RM15
Sabah/Sarawak - RM20
Item(s): BRAND NEW MONSTER CABLE BRAND NEW MONSTER SPEAKER CABLE (COMPETITION HOTWIRES-2)
Package includes: BRAND NEW MONSTER SPEAKER CABLE IN FACTORY SEALED ROLL (6M)
Price: OUT OF STOCK
Item(s): BRAND NEW MONSTER CABLE HIGH QUALITY 500 WATT POWER 4-GAUGE BAP-500 AMPLIFIER KIT
Package includes:
MONSTER 101263 PRODUCT FEATURES - (BAP-500)
- Two 24k gold contact 4 gauge ring terminals 3/8
- 18 ft. of 4 gauge Monster Standard power cable
- 3 ft. of 4 gauge Monster Standard ground cable
- In-line fuse holder with 60 amp fuse
- 16ft. of 18 gauge remote turn-on wire
- Cable ties
Price: RM450/--
Peninsular Malaysia - RM25
Sabah/Sarawak - RM50
Monster 101263 (BAP-500) High Quality 500 Watt Power 4-Gauge Amplifier Connection Kit. Your amplifier will only sound as good as the cables used to connect it.There's no way around it. Whether you're adding a new amplifier to your car stereo system or installing an additional one, you need power cables. If you're thinking about grabbing the first low-priced wire you find, think again. The quality of the cables you use totally affects amplifier performance. So, if killer sound is what you crave, you need killer cable to deliver the goods.
Monster Standard power cable provides instant power delivery. Monster Standard power cable meets the instant power demands of high power amps. You'll get low-loss, high current power transfer, so your amp can reach its full performance potential. Monster Standard features high purity copper and a special winding configuration, which greatly reduces noise pickup. Its flexibility allows for easy bending around corners and a quick, easy installation. And, a protective Duraflex® jacket resists harsh car conditions including temperature extremes, abrasions, and chemicals.
Monster Standard grounding cable provides no-hassle install and squelches noise. Poorly designed ground cables can pick up ground loops, which cause noise. Heavy-duty Monster Standard ground cable features only the highest quality materials, greatly reducing ground loop noise. Its flexible design makes installation easy, even in tight spaces.
Get all the power and performance you paid for. Monster's power cables provide instantaneous power, without distortion. This allows your amplifiers, speakers, and other components to perform their best. Monster Car Power products take your car audio system to a higher level. So, crank it up, and let Monster take care of the rest
Item(s): BRAND NEW MONSTER TMC2+ And TMC2- HIGH PERFORMANCE TOP-MOUNT BATTERY TERMINALS (Positive And Negative).
Package includes: 1 Pair MONSTER MPC P200 TMC2- & MPC P200 TMC2+ BATTERY TERMINALS
Price: RM120/--
Item(s): BRAND NEW MONSTER 24K GOLD PLATED AGU FUSES
Package includes: 1 SET (4pcs) MONSTER 24K GOLD PLATED 50A & 60A AGU FUSES
Price: RM40/-- for 50A AGU FUSES
RM50/-- for 60A AGU FUSES
Peninsular Malaysia - RM5
Sabah/Sarawak - RM10
Price: RM120/--
Price: OUT OF STOCK
Package includes:
- Cable ties
Price: RM450/--
Price: RM120/--
