Hello~
Juz wanna know.. wad is the better air fuel ratio for turbo car?? ofcoz i mean in hi rev with full boost.. 10? 11? 12??
white_bird said:ermm.. wad abt 12?? is it ok with 1.1 bar boosting??
Joeker said:Overly rich conditions results in excesive carbon build-up, overtime compression increases causing pre-ignition.
Also, carbon will also deterioate lubrication efficeicncy due to sludge.
vteckiller said:in our hot climate we should be running something like 11.8 afr at 0.9 bar to 1.1bar and 11.7 if 1.2 bar to 1.3bar to be safe and 11.6 if 1.5bar to 1.7bar and 11.2 if 1.8bar to 2bar of boost to be safe and not sorry. for anything like 0.7bar and below 12 is fine.
How bout 1.9 bar on SR 20 DET engine ? What the ideal ratio ? engine with JUN 272 cam , holset turbo charge ( like ar 70 infront / .58 back) , 550cc injector , 2 additional injector ( 450 cc / 850cc ) 2 fuel pump , hks piston , 1.5mm gasket , with side exhaust out from the bumper , Microtech MTX - 8 ecu..
rite now the ARF at 14.7 .
stroker_kit said:flamefox,
so, in a cooler country, a 12kg mass of 02 should take a smaller volume compared to a hotter country, where the O2 mass of 12kg takes a bigger volume to occupy..... but still, both engine supply 1kg of fuel to 12kg of air mass to get AFR 12...only that in a cooler country, the engine doesnt need to suck in air as hard as an engine that runs in a hotter county to get the same amout of air mass of 12kg..the less hard work the engine do, the more hp it can produce, is that what ur trying to say??? still wondering whether theoritical=practical..... =)
Similar threads | |
