Turbo timer with no turbo :)
May 20, 2006
Hey all,
Wonderin' if anyone knows wat i can use to make a replica setup as a turbo timer but with noy turbo as my accord doesnt have turbo nor am i considering to get turbo. Some of you might think this is stupid or dumb idea but people have der own styles.
Cheers
3rdGenAccord
NA???
la??
Replica setup meaning a same setup as a turbo timer but with no turbo...so instead of turbo timer cooling down turbo it will cool the engine :) hope u get wat i mean.
thnx
Fluffy
3,870
>>klang<<
NA - basically a non turbo engine.
actually..this topic has been discussed..very very bad discussion.:_: but i'll tell u wat is my opinion..
i understand wat u want..but a turbo timer wont really make much diff compared to a turbo engine.
*i know there will be some smart ass who's gonna say im wrong.and a turbo timer on a NA engine is useful bla bla bla...well,i dont wanna hear it.*
3rdGenAccord
yeh i approve your opinion. im just reasearchin if turbo timers does have anything to do with the turbo or is it just a timer hooked up to the ignition and they called it a turbo timer :p but i have a strong feeling as you said it wont have a big diff hopefully none at all.
evo5229
2,166
KL/Kedah/Penang
ohkay for me....turbo car usally dun have turbo timer on it...
they just put a turbo timer to their car of taking car the engine....because the
engine are very hot so it must wait it cool only close rite...
FOR non turbo car, u can added too.....u also help u for cooling....just that it not
very usefull for non turbo car....coz the HOT not as turbo car as HOT......
et5828
1,848
5
don be so down
get vacuum meter
it looks quite exactly like turbo meter and it moves accordingly to ur throttle
insane_ian
458
Subang Jaya
Hey fluffy lol..hahaha i remember that thread....
TT on non turbo car etc...
TermiziYeoh
1,380
Cheras , Sel
Yes apparently u can do that on Natural Aspirated car.Some said only for style but actually it does help to cool down the engine before we turn off the ignition key after some time of long run. Go ahead.Get full auto TT like apexi, besides the timer, u can monitor your air fuel ratio and o2.
by the way, "la" is one of our slangue.Hope u get what i mean.
TermiziYeoh
1,380
Cheras , Sel
et5828 said:
don be so down
get vacuum meter
Bro, I think he was talking about turbotimer not boostmeter.Correct me if Im wrong :_:
Darkax
103
Malaysia
no point adding stuff that is not so important... burns a hole in your pocket and also increases the % of ur car getting broken into... :_:
Raja_Mongkut
810
hmm apparently fatt is not 100% accurate. not even 80%.. so u may suffer premature or prolonged idling.
which timer can monitor afr n o2 together?
Adeen
2,726
6
kl
timer can monitor afr n o2..?? never heard of any....mine can only do auto timing, manual timing, and reading the voltage(volt meter)....:)
imoloq
1,069
25
A turbo timer is used to keep the lubricating oil circulating in the turbo for a few more minutes after the ignition is switched off. This is to prolong the life of the turbo. Let's say you have been driving at around Sepang circuit for 1 hour straight. Your turbo would be very hot right? A turbo timer prevents hot oil in the engine from cooking up in the lines by letting the engine idle for a few minutes. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine.
acbc
4,615
KD
I used to have a HKS turbo timer (4 button) on my NA car last year. Never even use it unless long distances such as Genting Highlands where u can activate the timer to cool down the engine b4 shutting it off.
Other than that... u be a laughing stock among turbo car owners out there... there is a name for this... "Poser".
TermiziYeoh
1,380
Cheras , Sel
Hope this helps.
Apex'i
The Apex Auto Timer allows the vehicle to idle for a preset amount of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine.
The Auto Timer stands as a technological marvel. The pen shaped, compact size makes the Auto Timer one of the smallest turbo timers on the market. This allows a clean and stylish installation virtually anywhere inside the car. The unique multi angle joystick button allows easy navigation through the many feature menus.
Upgraded in every way from the previous model, the new Auto Timer can automatically determine the necessary amount of after idling time. A Manual Mode allows the user to preset desired idling times from 0 sec.~10 minutes in 16 increments. By inputting O2 sensor voltage, the Timer can also display theoretical air fuel ratio. Since the Auto Timer uses the factory O2 sensor which is primarily designed for emissions, the readings may not be as accurate as racing air/fuel ratio monitors. The Timer can also display critical data such as O2 sensor voltage and Battery Voltage. To prevent potential theft while running, the handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key.
CONCEPT:
Provide turbos wind-down time
CHARACTERISTICS:
Easy to use; Simple and attractive design
Source : http://www.apexi-usa.com/product_electronics_detail.asp?id=198&pageNum=1
Fluffy
3,870
>>klang<<
yeah! total poser stuff for an NA car.
Doink
3,492
House
excuse me...there is really a use of a timer for NA engine also...if u always rev ur car kau kau...your car temp also raise kau kau....but i think most of the people didnt mod their cars so no need timer...try driving a high compression NA full throttle from down hill till up hill genting...see the temperature...and you will get the idea...
Rather than focusing on full-throttle performance, the Almera Turbo's HR10DET engine aims to fulfil real-life, daily driving needs with more low end torque.This 1.0L 3 cylinder turbo engine makes 100ps / 152nm and is used in the entire Almera Turbo lineup. It features an integrated electronic wastegate and Nissan GTR inspired Mirror Bore coated cylinder wall that promises better engine...
