Currently running GT35. me myself not convince by my mech saying that the 44mm is not big enuff. this is my third WG and i dun wan to waste more dough buying another one. first was cap ayam WG, boost it once the diaphragm gone. second was Tial 38mm, not holding boost give me spike everytime. this one 44mm still not holding boost good enuff. so is it WG at fault? just put in boost controller and get rid off tulang ikan...problem still same...set boost at 1 bar it still goes to 1.5 bar. haiya penin2
the way i see ur setup , its most probably the pipe that comes out from ur wastegate , whts the use bro having a 44mm wastegate and still use a 40mm pipe , its more likely restrictive , should be more than 44mm both sides for the pipes , 45-46mm , bro please bro , if u have a GT35R and a 44MM Tial , please do throw some money on a electronic boost controller like profec-a , evc or avcr , throw the sisik ikan, sisik ikan is also a cost for boost spike, u only use one nipple on ur wastegate for sisik ikan, if electronic boost controller, u use both the hoses, its for boost stability
i have seen gt30r on 38mm wastegate, they are doing more than fine , i have seen gt35r on 40mm its running fine too , 400hp cars running 38mm no problem also
