stock airtrek fuel pressure.
ipin
83
3,008
How much stock airtrek fuel pressure? Currently i'm using fpr and set to 3.5 kg/cm2. Found a bit increase in fuel cosumption!
ipin
83
3,008
or maybe someone mind to share what the FPR setting for stock td04 airtrek.
stutzedward
3,416
561
Bro.... I do not have any FPR in my car yet.... so can't help much. Plan to have this installed soon though together with higher rated fuel pump ...
ipin
83
3,008
thanks kaninbu, this morning just set to 3 kg/cm2. Accelerate feel more lighter.
ipin
83
3,008
fpr only with stock fuel pump. Td04 stock. Got walbro but not install yet!
ipin
83
3,008
I've tried set with various pressure. So far, with my stock setup, the ideal pressure between 2.8 kg/cm2 to 3.5 kg/cm2 (40-50 psi). More than that feel havier and fuel cosumption increase! Currently I set at 3 kg/cm2 (~42psi).
ckwanloong
160
11
I'm using td05 with stock fuel pump stock injector~ any ideas for my fuel pressure?
ipin
83
3,008
Just sharing a method to check either the engine is lean or rich. If u have the tuner with datalog or etc... better go for it! For me, simple method to check just by looking the spark plug head. If too WHITE = LEAN (LESS FUEL) too BLACK = RICH (OVER FUEL) the ideal is more about ABOUT YELLOWISH.
Read somewhere, For stock EVO VII fuel pressure is = 43.5 psi (vacuum off)
ipin
83
3,008
Q: How to set FPR?
A:
1) Stock fuel pressure is 43.5 PSI (>< 3.1 kg/cm2). So set you FP to that with the vacuum hose UNHOOKED .The
reason for the hose off for manifold pressure reference.
2) So under low pressure (vacuum) ie: vacuum hose connected, the fuel pressure should drop.
3) However high pressure over 1 Bar (when manifold absolute pressure is higher than 100KPA or 0 PSI(atmosphere))your FPR will add one
pound of fuel pressure for every one pound of boost that the turbo generates.
Similar threads   Forum
Car Modification
D General Talk
ICE -In Car Entertainment
MAC : Malaysia Airtrek Club
  Similar Threads
Car Modification
D General Talk
More photos from the Motor Sport Japan 2007, this time focused on the Rally Masters.For about half an hour, the attendance had the chance to witness some of the very best Rally machines that Japan has to offer with the "classic" WRC (World Rally Championship) cars such as Arai-San's Subaru Impreza WRX 2007 and Taguchi-San's Group N Lancer Evolution.
Again, Nihoncar.com covers the event
Also...
