http://malaysiangp.com.my/story/drag-battle-summary-sepang-drag-battle-2011
Wow!! 4 classes only !!!
CLASSES AND SPECIFIC MODIFICATION
Class A (Open)
1. Maximum engine capacity : No limit
2. Turbo, supercharged & Nitrous Oxide System (N.O.S) system are allowed.
3. All-wheel-drive vehicles permitted.
4. Roll cage is mandatory. (Please refer to Appendix III for roll cage drawings).
5. No minimum weight applicable.
Class B (2WD Limited Forced Induction)
1. Maximum engine capacity : No Limit
2. Either turbocharged, supercharged or Nitrous Oxide System (N.O.S). Only one allowed.
3. 2WD vehicles only.
Class C (2WD Natural Aspirated)
1. Maximum engine capacity : 2000cc
2. Only natural aspirated (Non-turbocharged and non-supercharged) engines are allowed.
3. Variable valve timing engines are allowed.
4. Nitrous Oxide System (N.O.S) system is prohibited.
5. Minimum weight required – Please refer to the table in Appendix IV.
Class D (Turbo SFWD) - Street Front Wheel Drive
1. Turbo-charges and SFWD (Street Front Wheel Drive). 4WD & RWD are prohibited.
2. Engines must be 2000cc and below. This displacement is referring to original factory displacement.
3. Rotary engines are not allowed.
4. Variable Valve engine is allowed.
5. Nitrous Oxide System (N.O.S) system is prohibited.
6. Tyres are open. Drag tyre is allowed.
7. Exhaust system is open.
8. Interior and exterior must be complete and present.
9. Wind screen, side windows and rear screen must be made of glass.
10.Safety is very important. Any car found lack of safety features will be prohibited from entering this class.
11. Minimum weight of 900kg per car all the time (without driver)
TYRES & WHEELS
1. Tires are open of make and type unless stated otherwise.
2. Wheels must be automotive-type suitable for street use. Space-saving spare wheels are not permitted.
OTHER SAFETY REQUIREMENTS
1. Interior
Seats – must be properly braced, framed and supported seats constructed aluminum, composite material, double layer poly or fiberglass (automotive accessory seats) permitted.
Seat belt is mandatory and must be worn all the times during the meet. Minimum is 4 point harness.
Fire extinguisher is highly recommended.
2. Protective Clothing
All drivers are required to wear full-length pants, proper shoes, socks and gloves. Nylon or nylon-type clothing and open-toe shoes are strictly prohibited.
Full racing attire (including shoes) is mandatory for Class A & B.
3. Helmets
All participants must use an approved crash helmet during the meet. Approval of crash helmet is entirely at the discretion of the Scrutineers.
---------- Post added at 09:32 AM ---------- 6 hour anti-bump limit - Previous post was at 09:28 AM ----------
SDB 2011 Sporting Regulations
http://malaysiangp.com.my/files/u1/pdf/Drag11-Sporting-Regulations.pdf
---------- Post added at 09:33 AM ---------- 6 hour anti-bump limit - Previous post was at 09:32 AM ----------
SDB 2011 Entry Form
http://malaysiangp.com.my/files/u1/pdf/Drag11-EntryForm.pdf
