guys...need help...
can we list out what are sensor do we have...
priority for 4AGE 20V (SVT/BT)
need help...
some of the list...is there any thing left out...???
Boost Sensors
Cold Start
Communications
Correction Factors
Crank Position
Diagnostics
Engine Temperature
Fuel System
High Altitude
Idle Up
Ignition System Control
Injection Duration
Injector Duty Cycle
Knock Sensor
Load Signals
Neutral Start
O2 sensor
Oil Pressure
RPM Signals
Starter Signal
Stop Lamp
Throttle Position
Vehicle Speed Sensor
Thank you in advance...
need help...
Boost Sensors
Cold Start
Communications
Correction Factors
Crank Position
Diagnostics
Engine Temperature
Fuel System
High Altitude
Idle Up
Injection Duration
Injector Duty Cycle
Knock Sensor
Load Signals
Neutral Start
O2 sensor
Oil Pressure
RPM Signals
Starter Signal
Stop Lamp
Throttle Position
