I have a new ScanGaugeII v.3.17 for sale.
Item location is Damansara Perdana.
012-2085178 Lionel.
The Ultra Compact
3-in-one Automotive Computer
Trip Computer - Digital Gauges - Scan Tool
The integrated Trip Computer provides realtime feedback while simultaneously tracking three sets of trip data. The Digital Gauges give you realtime data for your vehicle and the built-in Scan Tool allows you to read trouble codes and diagnose potentially expensive problems before they get out of hand. All this in a small and simple to install unit that can be easily moved from vehicle to vehicle.
Linear-Logic Presents
The All New ScanGaugeII
Compact size
Fits almost anywhere!
Works On 1996 or Newer Vehicles
Including: Gas, Diesel, Propane and
Hybrid Vehicles
Detachable Cable
Allows for easy portability from vehicle
to vehicle.
Menu Driven Operations
No need to memorize complex sequences
Works On All OBDII Protocols
Including CAN, required on all vehicles
starting in 2008.
Large High Contrast LCD
User changeable backlight color
Easy to Install
Connects In Seconds
The cable is detachable at the ScanGauge II and can be connected on the back or side of the unit. Once connected to your vehicles OBDII port, the ScanGaugeII automatically negotiates communications with your cars computer - It's that easy!
Compact Size
Fits Almost Anywhere The compact size of the ScanGaugeII allows you to mount just about anywhere. it's so small, you can even slip it into your pocket and take it with you.
The dimensions of the ScanGaugeII are 4.8" wide by 1.5" high by 1.0" deep. The cord from the diagnostic connector to the control/display is 6' long and about 0.2" in diameter.
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
Learn more ››
DIGITAL GAUGES
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
Learn more ››
Read and Clear Trouble Codes
BUILT-IN SCAN TOOL
The ScanGuageII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
Learn more ››
View Photos
of the ScanGauge II
View a series of photo of the new ScanGaugeII
Photos ››
ScanGaugeII Photos
The dimensions of the ScanGaugeII are 4.8" wide by 1.5" high by 1.0" deep. The cord from the diagnostic connector to the control/display is 6' long and about 0.2" in diameter. The following photos give a better idea of what it looks like and how it can be mounted.
ScanGaugeII Photos IMG_3696.jpg IMG_1988.jpg IMG_1993.jpg IMG_1996.jpg IMG_1999_Amber.jpg IMG_1999_Aqua.jpg IMG_1999_Blue.jpg IMG_1999_Blue_2.jpg IMG_3680.jpg IMG_3685.jpg IMG_3686.jpg IMG_3687.jpg IMG_3687_3688_M.jpg IMG_3688.jpg IMG_3692.jpg IMG_2006.jpg In Use Photos IMG_3154.jpg IMG_3156.jpg IMG_3196.jpg IMG_3202.jpg IMG_3212_M.jpg Retail Packaging
012-2085178 Lionel.
The Ultra Compact
Hybrid Vehicles
to vehicle.
starting in 2008.
Connects In Seconds
Learn more ››
Learn more ››
BUILT-IN SCAN TOOL
Learn more ››
of the ScanGauge II
Photos ››
ScanGaugeII Photos
