Satria-gti performance enhancement
KGhee
25
1,503
To fellow enthusiast out there, need some opinion on what is the most optimized engine performance i can get with a ~rm5k budget. My current ride is all stock, no mod done. As for the performance range, looking at increasing the low-mid rpm range. As of now, looking at either NA mod or supercharging (not sure if within budget though). Appreciate the feedback.
KGhee
25
1,503
Guys, thanks for the suggestion. Couple of questions though:
Aaron: What do you mean by the MIVEC head? Just the cylinders head?
Boyzone: For low-boost BOT, does that mean the engine internals (heads, rods etc) need not be changed? And, how much would this mod improve the drive-ability in the low-mid rpm range?
Bear with me if some of the questions i have here is a little amateur-ish :P
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
5k for supercharging or turbocharging is barely enough... i would suggest NA mods...
- full tuned length exhaust mod
- drop-in k&n air filter
- lightened crankpulley
- safcII / emanage
- port n polish intake
boyzone
2,669
38
5,148
Yup, no need to change.
low boost will not give u strong pulling, just a comfort like saloon car :biggrin:
mizi0604
179
6
change to mivec head...if you want to change head only oso can,but need to add Rspec to active mivec but the power is not as strong as if you change the whole things...better to get head,ecu,wiring,intake,throttle body,extractor and bla bla bla or all above your block change to mivec parts...
within 5k budget,i think you need to sell back your 93 head and all above your block,then it will be enough coz to get mivec head and bla bla bla is so expensive now...:biggrin:
long live to MIVEC~!!!:driver:
EGNINE
513
65
3,028
just curious..if 4g93 change to mivec head..do JPJ 'kacau' if they conduct 'operasi'..is it illegal or legal?
Bump: just curious..if 4g93 change to mivec head..do JPJ 'kacau' if they conduct 'operasi'..is it illegal or legal?
mizi0604
179
6
it is legal bro,they only check on your block whether you punch number on it or it is original...they also check on your exhaust system sumtimes...dont go straight below your fuel tank...but mine also straight below tank...:biggrin:
just slow down your car if u facing the jpj road block,dont use very noisy muffler...
TIPS: jpj loves to stop your car if you hood is in black colour and white body...thats what i heard from jpj itself...:biggrin:
xinghonh
1,415
7
bot it...max can go 1 bar...but muz use thicker gasket and a good setup
mine got ard 214hp 0.9bar
cheers!
aarion
609
you have to ask yourself. TURBO or NA. then we will do the recommendation. TURBO no end. NA got limitation but i would say enough for street and even occasional track.
KGhee
25
1,503
Hmmm, after some thinking thru...i would prefer to stick with a NA setup. Main reason is i'm more interested in improving the drivability of the car in the low-mid range.
gtiwtks
157
KGhee,
Just follow bro skywalker recommendation if you want low mid range for NA way ... It would be better if you can add in a street cam... like 268... Else you can go for turbo kit... no need to high boost... confirm increase low mid range... some one selling at the market place... installation plus tuning only less then 5k.... check it out...
JackWaiKit
262
5
www.friendster.com
BOT might casue u more...in case if u need to up boost, u have to mod oil pump, low compression piston, intrercooler
My 1.8 MIVEC:love: is not that power...maybe i don't put enogh $$ into it...!!!
But can play with BMW brand new 5 series geh...:burnout:!!!
But don't compare with GSR lah...:banghead:
popout
366
anyone modify simems based 4g93p ??mind share most of the ppl recommended convert to mmc based, my pocket not deep enough to convert mmc. any recommendation beside change to mmc??
mzs_15
223
Putrajaya
change to mivec head,also the wiring and ecu..then install RSM..n the power always come..
if u use the same block ur engine number is the same..jpj akan cek no enjin.only change the mivec head..
fevernova_xx
40
totally agrred. siemen based gti is like a curse. cannot do any tuning.i change to gsr ecu altogether..
mivec RS
49
hai bro new guy here ,
i already did 1.8 gti plus mivec head with flat piston(81mm) . 150whp .
:biggrin:
zac
1,347
231
Johor Bahru
I will suggest go for BOT, boost at 0.7bar very safe, and the power curve are linear... : ) tried before very attractive, perhaps just add a nigger radiator then nery nice for daily drive...
Im driving 1.8mivec, but not recommending him to change to mivec head leh, cos very leceh, and power really so so only (although can outrun lexus IS250:thefinger:maybe he isn't playing but i knew he was) unless rev high, furthermore he still using ori gb right?? is it close enough for mivec roar??
GSR06
455
17
If you wanna modify, go for the best la...later on, half hanging here and there...or later will complain not enough power.
hi guys..
i've just bought a 2ndhnd Satria 1.3(M)..
my prob is, it comes without the user's manual.. :banghead:
is there is anything that i can do(fast n easy) to get it.. :idea:
