REV Performance Garage Sales !!
andysky5
33,386
55
1,648
- All Parts are New and Genuine, unless stated otherwise.
- We provide Warranty for our Products...so you have no worries if anything goes wrong !!
:biggrin:
Engine Performance parts :
WORKS Enginnering Products
Fuel Bank Evo II - HOT !!
NGK Iridium IX Spark Plug
NRG Racing Meters
EPS Power Charger
Sard Fuel Regulator - Original
Adjustable Fuel Regulator (Sard type) - Hot
Works Engineering Ball Bearing Air Charger
Super Ignite RSD
Surpass 9.8mm Performance Plug Cable
Original Tial Wastegate 38/44mm
Tial style Wastegate
Tial MVS Wastegate - Replica
Manual boost controller - Hallman
Manual boost controller - Turbosmart
HKS SSQV replica Bov
Greddy Type-RS Blow Off Valve - New
Adjustable Fuel Regulator (OEM type)
Throttle Body 65/70/80mm
Honda b-series 70mm throttle body - New
Air Conditioner Lubricant
P2R Adjustable Cam Pulley
Aluminized Thermal Cloth
Aluminium Pulley Kit
High Capacity Fuel Rail Kit
Honda B16a/B18c Vtec Adjustable Cam Pulley
Exhaust Thermal wrap
Oil Catch Tank - New
Cusco Oil Catch Tank
Nissan SR20 Performance Parts
Thermal Intake Manifold Gasket
NGK Power Cable
Bubble remover tank / Breather tank
Magnetic Oil Sump Nut
Skunk 2 Resevoir Cover
Engine Damper Kit
Power Enterprise Timing Belt
Walbro 255lph Fuel Pump
Turbo Manifold for GSR 4G93T / Evo123
Performance Intake Manifold
Tomei Camshafts
Piper Racing Camshafts - New
HOT BITS SS Extractors - HOT !!
Spoon Reservoir Cover - Nice !!
Transparent Timing Belt Cover
Cometic Metal Head Gasket
EXEDY Racing Clutch
TRINITi Racing Clutch - NEW
T-Bolt Hose Clamps
KAAZ Transmission Gear Oil
Intake System & Filter
Apexi Power Intake
Open Pod Air Filter Kit
WORKS Engineering Drop in Filter
Project S Super Stainless Drop in Filter
HKS Power Flow Reloaded
HKS Filter Element Dry 3 Layer
Stainless Steel Filter
Real Carbon Filter
UTR Super Flow Performance Drop in Filter - hot
Simota Twister
Pipercross cold air Intake duct
Cold Air Intake Hose Kit
Intake Air Ram Pipe - New
Electronics
NRG Meters - NEW !!
Shadow E-Drive Throttle Controller - NEW
Sports Meter - New
Pivot Shift Lamps - New
Apexi AFC Neo
Greddy Emanage
Pivot Raizin VS-E Volt Stabilizer
Greddy Boost Controller
Apexi Boost Meter
Shift Lamp
V-Manage Ignition Amplifier
Apexi Pen Timer - New
Turbo Timer
Engine Start Button - Hot
Ignition Earth
Grounding Cable kit
Direct Ignition Panel
Digital Volt Meter
Electric Fan Temperature Controller
HKS Style Grounding Cable Kit - Hot
Silicone hoses :
Silicone Radiator hose kit - New
Samco Silicone hose
Samco Vacuum hose
ASR Silicone Elbow and Reducer
HKS Vacuum hose
Cooling parts :
DEI Performance Coolant Additive - Hot
Performance Aluminium Radiator
Wira, Satria, Putra, Evo and Civic eg/ek Performance Radiator
Honda EG/EK Aluminium Radiator
Engine Oil Cooler Kit - New
Engine Oil Cooler
Intercoolers
ARC Intercooler
Automatic Transmission Cooler Kit
12" Performance Electric Fan
Braking system :
PRO-RS Braided brake hose
High Performance Brake Pads
Brembo Brake Fluid
Sports Brake Rotor
Interior / Exterior and Body parts :
Works Engineering Gear Knob - New
Bride Low Max Seat
Philips crystal vision
Real Carbon Plate
RX7 FD3S Re-Amemiya Vented bonnet
Nissan S15 Vented bonnet
D1 Bonnet Pin
Sparco bonnet pin
Sparco Rear Pin / Hook
Aerodynamic Number Plate Holder - New
Gear Short Shifter
RECARO Seat DC5 - Black
Suspension parts :
Adjustable Suspension Kit For Proton Cars - NEW
CTECH Chassis Stabilizer Bars - NEW
Drag & Drift Full Adjustable Suspension - Cool !!
BC Racing Adjustable Suspension - HOT !!
BC Adjustable Suspension
GAB Suspension
Rear Lower Arm bar
Suspension kits for Nissan RWD cars
Honda Adjustable Suspension kit
POWERFLEX Polyurethane Bushing
Rear Suspension arm for Proton Wira, Putra and Satria - New
Room bar
Adjustable Front / Rear Camber & Toe Kits
Car Audio :
Focal and Zapco products
Others :
Alloy wheel nuts
Sports Wheel Nuts - New
Oil Temp/ Pressure Sensor & Cooler Adaptor
Water Temperature Sensor Hose Adaptor
RB26 GTR OEM Injectors
[MAP] Sunway, Petaling Jaya, Selangor, malaysia[/MAP]
Address :
No.7, Jalan PJS11/24,
Bandar Sunway,
46150 Petaling Jaya, Selangor.
Note: On top of GT Pro-Shop (ex Monster Garage), same row as Teck Ming Silverstone tires near N1 racing.
Operating Hours : Monday to Saturday ( 11am - 7pm )
Please pm or sms for COD at Rev Performance, Bandar Sunway or Postage by GD Express ( postage will be charged ).
My contact no. is : 017-3526055 (andy)
Bank In Details :
Bank : Maybank
Account no : 112231051159
Name : Low Chun Hung
More products coming soon !! TQ :burnout:
andysky5
33,386
55
1,648
We will be closed from 17th - 19th for Deepavali. Tq
Beijing Auto International Corporation or BAIC has officially launched the D20, a 5-door hatchback with styling said to be derived from the original Mercedes-Benz B-Class. To be locally-assembled either in Gurun or Pekan, it is a joint venture between BAIC (pronounced as baik) and local partner Amber Dual.
BAIC D20
