Racing Solid Engine Mounting For Wira 1.3/1.5/Evo/GSR/Mivec
khguan
4,818
26
Seri Kembangan
fotopic.net
One pair of solid engine mounting to let go.
Brand New item.
Bottom 2pcs (front n back) engine mounting on crossmember, plug n play.
Full rubber, not too hard. Less vibration compared to other solid mountings.
RM180 per pair as shown in picture
1st come 1st serve. Installation can be arranged.
Interested pls contact me at 012-270 8685 (Guan).
*** Left n right engine mounting also available.
Cloudz
63
Bro i'm presuming it can fit Satria Gti.
By the way, I'm actually looking for manufacturer name i.e Powerzone or Speedworks or something like that lar.
Where is you shop in serdang, interested leh.
khguan
4,818
26
Seri Kembangan
fotopic.net
yes.. the mountings are direct fit into GTi (wira head cars)
my fren GTi using these mountings.. better pickup.. and the best thing is the car doesnt vibrate... only a bit of vibration when the aircon kick in when the car is at idle.
the brand name?? lets give it a name.. "Guan Customs" sui boh?? hahah... anyway this is a small production item... if they put a brand name.. it will be much more expensive...
btw this is my own stuff u can either come to my shop in Bukit Jalil to collect or COD with me at Serdang at nite. Installation can be done in my shop anyway. Of cos with a minimal labour charge.
Whatever it is.. just gimme a call for easy deal. THanx!
Cloudz
63
Bro,
Wher's your workshop? can drop by this weekend to check it out. If ok then I just install there and there.
i have a bad experience in these custom made stuff, will share with you once i'm there. Thanks!
By the way, the picture looks promising.
khguan
4,818
26
Seri Kembangan
fotopic.net
well it is not custom made.. the factory specially made these with more rubber to cater for performance ppl which always have problems with stock mountings... especially those with transplanted engines.
hello all...
does anybody know any pistons from any engine which has bore around 78-79 mm n stroke around 83-84 mm and can withstand a compression ratio of 11:1?
I know, some might say this might be a 'long shot' search n I'm better off with a custom pistons. However, im trying to reduce cost in rebuilding my engine. Sharing of any info regarding above is greatly appreciated..
thanks in advance..
