clarion 24bit usd/cd/mp3 player
clarion dxz586usb (brandnew malaysia warrnty)
location kelang lama batu 3
DCP
Remote Control
USB model with connectivity to support a variety of digital media.
This model is equipped with 6ch/6V RCA outputs, connect directly to your iPod so that you can control it via your car system, and for enjoying futuristic system upgrades to your car. With support of the digital rights management format WMDRM10, and the playback of audio files via a USB link, it realizes a car multimedia style for seamless entertainment both in and out of your car.
LargeView
Clarion takes H.M.I. to yet another level with the introduction of SLIDETRAK. With a simple swipe of the fingertip, it provides precise control of the key features on the head unit.
Bluetooth® ready
LargeView
Handsfree conversations on Bluetooth ready mobile phones, supports greatly the safety in driving. Conversations are possible via wireless connection of the phones to the vehicle audio systems. With Bluetooth ready iPods, music reproduction from and control of iPods can be done through the main unit.
6-volt/6-channel output
LargeView
Equipped with 6V/6ch outputs for reproduction of sources with high sound quality. Together with crossover settings, it can be used to output to various speaker systems like Front 2ch + Rear 2ch + Subwoofer 2ch.
Direct USB iPod® control
LargeView
You no longer need an expensive adapter box or interface cable to connect your iPod to your Clarion source unit. Simply connect the USB cable included with the iPod to the front USB input for battery charging and complete control of your iPod.*
LargeView
Support for audio compression formats such as MP3, WMA, and AAC, and digital rights management WMDRM 10 format, link with an iPod, and improvements in connectivity with USB devices - all these make it possible to seamlessly enjoy music with a variety of digital media.
Requires a portable audio player that is compatible with WMDRM 10 data playback.
13-segment 2-line display
LargeView
The 13-segment 2-line display enables display of a multitude of information. As a visual interface between you and the source unit, it offers clear display of what’s playing with numerous setting and selection possibilities.
Digital Z-Enhancer sound customisation
LargeView
The Digital Z-Enhancer lets you choose from 3 equalisation patterns to restore tonal balance by freely accentuating each of the high and low frequency ranges. Thanks to 6-step gain adjustment of 3 separate preset patterns, tailoring the sound to your system speakers and the selected audio source is now possible.
24 bit D/A converter
A key component in the transfer of digital data from a CD into analogue sound is Clarion’s 24-bit D/A converter. Because the digital realm is made up of unnaturally square sound waves, as opposed to the smoothly undulating sound waves characteristic of the real-world environment, Clarion’s embedded 24-bit D/A converter recreates the natural nuances and expressions lost during the sound reproduction process.
2 band Parametric EQ
Dividing the sound spectrum into 2 bands, the parametric EQ allows equalizing of the frequency curve for customization of the sound character according to the speakers used and the acoustic properties in the car.
High Pass/Low Pass Filter
You can set the frequency range of the audio signal that's output to each channel, to best match the acoustic characteristics of the front, rear and subwoofer. This is also possible even if you decide to connect your original speakers directly to your main unit without an external amplifier. The High Pass Filter is also available to cut off frequencies below 50, 80 or 120 kHz.
location jalan kelang lama batu 3
pls call 0162228108
DCP
Remote Control
- CD-R/RW ready
- MP3, WMA and iTunes® AAC compatible
- Front USB slot with maximum track capacity: 130,560 (255 tracks in 512 folders)
- WMDRM 10 playback for USB Digital Media Streaming
- 18 FM, 6 AM station presets
- iPod® direct control via USB
- Subwoofer level control
- 24-bit D/A converter
- Sound Restorer
- Digital Z-Enhancer
- 2-band parametric equaliser
- Built-in High pass filter & Low pass filter
- 4-channel × 53 watts MOS-FET amplification
- Flip-down console
- High visibility 2-line display with Screensavers
- "SLIDETRAK" for dynamic operation
- Cellular input and Phone mute
- Auxilliary input with level control
- 6-channel audio pre-out
- CeNET control of 6-disc CD changer
- AUX Bluetooth transceiver BLT370 ready
- OEM steering wheel remote wired interface capability
LargeView
Bluetooth® ready
LargeView
LargeView
LargeView
- * Use the USB cable supplied to connect the iPod.
* See the Clarion website for iPod models that can be connecte.
LargeView
LargeView
LargeView
pls call 0162228108
